Is this possible? The usage is like this:Incoming PSTN line is split from the wall to go to 1) UC520 (FXO Port 0) and 2) home phone.UC520 should not answer incoming calls on FXO port 0, but should be able make calls using FXO port 0.Regards,Luis
Hi,all the vendors are puting wideband codecs in their line of phones (even Grandstream). When can I expect that wideband codecs are introduced to SPA series of phones (G722 to begin with)?Regards,Ognjen
I must've been trying for 5 or 6 hours now, to find specific info on how to update my 7975G to latest firmware for hookswitch headset compatibility. The release notes for 7975G firmware 8.4(3) (attached) mentions a .exe file that fails for me everyti...
Hi there, I have a question in regards to intercom and shared lines.SPA 400 1.1.2.2SPA 9000 6.1.5SPA 942 6.1.3(aSPA 922 6.1.3(a)I have spa 9000, 400 combo with 2 x spa 942 and 2 x spa 922Extension listext 100 spa942 (shared line apps 101,102,106)ext ...
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in ...
From time to time when we do troubleshooting on customer equipment we run into log lines that state a "reboot reason", I have been unable to find a document describing what errors these codes (for example c200, c40000 and so on) resolve to. Is there ...
For partners looking for localisation information and troubleshooting please refer to:https://supportforums.cisco.com/docs/DOC-10058ThanksLuke
Can an phone user configure his/her own personal speed dials on the phone. ? The Local speed dials could be updated using the CUE GUI, but there is no option to do a personal speed dial. Also when the speed dial is configure, any idea how to access...
I am continue to get confusing information regarding licensing. My scenario is this : I have a law firm that needs 9 phones active. I have been told I can use 1 8 port UC520 and 1 8 port CE520 switch.The reason: The 8 port 520 comes with 15 voice mai...
Can I use a linksys BEFSX41 VPN endpoint with the integrated easy vpn server in UC520ThxFilip
Dears,What will be the best way to connect the UC520 behind a Cisco router 876W for ADSL.In holland we have to use a ADSL router first and then the UC520.At this moment the SIPcommunication from the outside world will not reach the UC520.Any help is ...
From John Vickroy, UCC Product Manager: Within the past three weeks, we have performed End User Training on the Cisco Unified CallConnector for Windows (UCC) product for a few end users who are Beta customers for the new version of UCC v1.5.In the mo...
I need to upgrade a UC500 CUE to latest version. I have installed CCA 1.8 The CCA has an upgrade function by either dragging and dropping or using the window option to select files. Question: 1. Has anyone upgraded a UC500 CUE 2. Is using the CCA ...
I misplaced my getting started guide. Does anyone know where I can find one that I can download?
I was wondering if anyone knew if the new Cisco Configuration Professional software was going to be compatible with the UC500 units? I tried to discover one at a client site and it said it didn't support the hardware. Also, I was told by a colleagu...
