We want to broadcast a SSID (and allow users to connect) between certain times each day, and then take it offline. Unfortunately we dont have prime and only DNA Essential Smart licencing. All document...
Hi all,I am looking for some guidance here, and I am quite certain that some of you, great minds, will be able to stir me in the right direction here. And a big thanks in advance. Here we go, i have ...
Hi to all I purchase new AP C9120AXE converted to EWC.I notice when AP is booting a message related to default route not set that it says that can affect performance.Message is : %Default route withou...
Hi all, I am trying to convert AIR-AP2802I-B-K9 from CAPWAP to ME using this guide https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/1/user_guide/b_ME_User_Guide/getg_start.html#task...
Hi All, Currently i have a 9800-cl wlc with 2700, 3800 and 9100 series access points (internal APs). All three APs broadcast same SSID with (WPA2/PSK) for come legacy clients which operates on 802.11b...
With the latest security software and the ability to set up in minutes, it's no surprise Meraki Go access points were Cisco's number one seller on Amazon this week.
See how Meraki GO works for you
Q1 - Can 8500 WLC do SSID Schedule ?A1 - if Yes, Q2 - what version of sofware do i need to upgrade my WLC ?
Hi Guys,I was looking for a while now over the internet for possible confirmation if this is possible. Bear with me as I am not too well verse in wireless.Is is possible in Mobility Express to integra...
We are getting the following error message multiple times on an AP migrated to SD-WAN (travelling via IPSEC instead of previous MPLS WAN Link), meaning encapsulation for CAPWAP + IPSEC Encap. *Aug 19 ...
Hi, I am seeing below error message in 9800 WLAN controller for few clients, DNA Center says group key update timeout.APs are 3802's, any advise would be much appreciated. 2020/08/13 10:16:49.912058 {...
Hi, Anybody knows how to pull detailed report that showing all APs CDP neighor switches of WLC? Can see one by one through CDP->AP Neighbor, but we have almost 300 APs and bulk report of that, we hav...
We are pleased to announce the immediate availability of the IOS-XE release 17.3.1 for the Catalyst Wireless Controllers. The new code is now posted on the CCO and can be found at this link:
https://s...
This tool is essentially used to generate basic and best practice configurations for the 9800 Controller. The basic configurations include Day 0 Config, Central and Local Webauth, Dot1x, PSK etc. The ...
Do you have hands-on experience with wireless network management?
If yes, please participate in this quick online survey. We'd like to understand your wireless network management and job roles that...
Hello , We faced issues with Cisco AnyConnect when trying to connect at home network. we have 2 scenarioScenario 1: one home network and Cisco AnyConnect gives "limited or no connectivity" error mess...
