Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Does anyone have a best guess answer as to when we might see a 802.11n wireless bridge similar to the WET200? The current product has been out for a while, and I would love to replace my D-Link DAP-1522, but it's 802.11n and has GigaBit ports... get...
I've been searching high and low and although I've found many results of people having this same exact problem there doesn't seem to be a fix, or at least no one was kind enough to post one. Background:I have many vlans but the 3 in question are 10, ...
I have a WRV210 router setup with WPA personal-AES encryption...SSID is turned on. The issue is that workstations lose connectivity to the internet and to a mapped network drive on the server. When this happens I find that the wireless status shows...
I have a client that has 3 AP541N's and they want to enable guest wireless access. However, their VOIP provider has their managed switches locked down so we can't add VLANs, etc.So I cannot touch the switch or router config on this LAN.Looking into A...
Добрый день!Нужна помощь в настройке оборудования, я сам настроить не смог.Итак, я имею Linksys E3000 в качестве роутера, но его Wifi недостаточно силен и ноутбук не видит его в другом конце квартиры.Я решил использовать WAP4410N в качестве репитера,...
I have two AP541N's (running the latest firmware - v2.0.0) which I recently started monitoring via SNMP. Everything appeared fine until I rebooted the devices and noticed that the uptime was coming back as 200+ days. At no point in time have I been...
My new Coby tablet model #MIC1125-4G does not connect to my wireless network which is secured with a WEP key. The tablet connects everywhere else (Starbucks, etc.) and all my computers work in my wireless network. My router is a model #WRVS4400N. ...
Hello,i have some Wireless Connection trouble with a Cisco Router (WRVS4400N-EU) and a iPhone 4.These are the current problems with my Cisco router:Conection with the iPhone 4The wireless connection is set up and working. However, after a long standb...
Hi,I am now very used to the SG300 smartports features and use them happily with a UC320W and multiple spa504g phones around the house. On the SG300 this typically involves trunks with 1UP management vlan and 100T voice vlan going to each switch and ...
I have a WAP4410N-A V02 with firmware 2.0.4.2 for my office and the same at several client locations. The problem I see with all the units is that, for N-mode connections, the maximum reported connection speed is 130Mbs at both the WAP and the client...
Does Cisco have an official number of how many AP541s are supported directly by a UC560? these are standalones and I know they are configured in a max of 10 to a cluster, but how many clusters can you have? We are looking at a hospital installation...
Hi thereWe are using a Qnap Turbo NAS in our office. Since we changed our router to a Cisco DPC3925 we can not see the Qnap Turbo NAS drive anymore when connected to the network via wireless connection. As soon as we plug an ethernet cable into our M...
HiI have several AP541 (on different site locations) which I have currently configured for WPA enterprise using windows 2008 as the Radius server. This works fine for staff members who use the wireless when roaming around the offices.I would also lik...
Hi there,I noticed a few discussion about Cisco Wireless bridges not being able to pass DHCP requests from clients.In my case I have a WET200 successfully associated with a Deliberant DLB2700 access point. When client computers are configured with st...
Hello,I've just purchased a WAP4410N-E V02 for home use and I'm experiencing some strange problems. Whenever the device is close to other electrical devices, it slows down until it eventually grinds to a halt, sometimes requiring a power cycle. I c...
