Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi,I have a Cisco WAP4410N setup in a conference room and have users who run the Cisco VPN Client 4.8.01.03.00. When they are on the WAP, they get booted off their VPN connection. When they are hard wired, they have no issue. What could my problem be...
i!We need to use WET200 as Access Points in our wired network with mix wirelss devices. We connected WET200 with network cable with a static ip and used the SSID of our network with a channel gap of 5 from nearby access point but it did not work and ...
Do the WET200 have to be operated as a pair, i.e. be on both networks when used as a bridge, or can they interoperate with any brand on one side of the bridge?
Sad sad sad Cisco.. No response? Do you even care?I wonder who will be at the xchange event in Dallas this year.Cisco how do we get refunds? not only for the time wasted on these things but for the hardware itself!!I was just talking to someone today...
I have a new WAP4410N AP that was put in service a couple weeks ago. After a few days of normal operation, the AP hangs. Typically during a large file transfer. To fix, I have to power cycle the device.When this occurs, all of the lights on the dis...
I gave up. While on hold two hours, just to speak with a tier 1 tech, I've been reading other forums on this product, leaving my bad reviews. No matter where you go, almost every one seems to be having the same issue. Several people on different for...
With over 45,000 views, something must be wrong. Like many of the others here, we can't work out what's wrong with our network and why the cisco 4410n behaves so badly.Our experience is just like everyone elses. At some point in time, mainly between ...
I am trying to create a wireless bridge between a network with ip's 198.1.1.xxx (this network has the gateway) to a network with ip's 198.1.2.xxx - so that it can access the internet thru the gateway). Both AP's are WAP54G set to bridge mode. Both ...
Hi,I have buy an new wireless router WRVS4400Nv2 and upgrade the firmware to version 2.0.0.8.I have the problem that this router not connect to my ADSL modem with PPPoE settings.I borrow another three router from my friend one Netgear WGR614 and one ...
SirsWe are receiving an increasing number of complaints from our customers that their ADSL lines are disconnecting randomly.We have together with the country largest telco operator faulttraced the lines now for 2 week and the conclusion isthe the WRP...
I have a WRVS4400N v2 acting as a gateway connected to a cable modem and am interested in extending it's range by placing a WAP4410N elsewhere in the building to cover a deadspot. Is there a mode on the WAP to best achieve this (e.g., wireless repea...
Hello everyone,I am having 3 cisco wap4410n devices. i want to use them only in my home. i dont want to connect to internet. i want these devices only for intranet (only LAN) purpose. Means to transfer audio, video, songs through these devices. then ...
Hi, I bought several WAP4410N Access Points. One is used as an Access Point with two SSIDs.I want the other ones to work as repeaters for these SSIDs. Each time I use the option "Allow wireless signal to be repeated by a repeater.", the second SSID ...
A while ago I had posetd asking if anyone knew of an AP that would be able to wrielessly repeat traffic to my SA520W (so that the AP has no ehternet wiring at all). The answer someone had posted on here (or in emailt to me, can't rememberr) was the ...
Hi, new to the site and need some help. We purchased 4 AP1232AG access points, intending to use 1 as a router and the other 3 as repeaters. We've spent the past week running power to the repeater locations, installing poles and NEMA boxes, lightning ...
