08-27-2014 01:40 PM - edited 03-14-2019 01:48 PM
I am trying to setup silent monitoring on Cisco Finesse and getting following error message on Finesse Supervisor Desktop Client:
Unable to Silent Monitor at this time (CTIError=Invalid Authorization User Specified)
Does anyone know the root cause?
Vaijanath
01-28-2015 11:03 AM
You got the solution, I am getting same error .
01-28-2015 01:05 PM
01-30-2015 02:00 PM
You don't say if this is UCCX or Enterprise
Make sure your jtapi user has "Standard CTI Allow Call Monitoring" set under permissions.
If this is UCCX then it should have set that permission when it created the jtapi user, Enterprise you will need to set it
Graham
10-10-2015 08:46 PM
Hello Graham, sorry to bug you with this old post but I am same difficulties. We have CCX Premium HA cluster and just getting ready to deploy Finesse. When you said ' Make sure your jtapi user has "Standard CTI Allow Call Monitoring" set under permissions...' you mean the agent should have this or the Supervisor? If it is Supervisor, I have this option configured. Thanks
10-11-2015 03:45 AM
Hi Graham,
Please find below all the information that you need to know about setting up Silent Monitoring on Finesse:
Configuration For Silent Monitoring:
++ Configure an test agent on UCCX with an unique IPCC Extension.
++ Make sure that the agent phone has the Built in Bridge (BIB) On. This can be done on the phone or at the Cluster level by setting the Default Parameter to On.
++ Login the agent to Finesse.
++ Make sure that the Supervisor is also logged into Finesse and is in the NOT READY state.
++ make sure that the Supervisor also has an unique IPCC Extension.
++ Ensure that the RMCM user has the required roles for Call Monitoring and Call Recording which is Standard CTI Allow Call Monitoring and Recording. Note: This is automatically done by CCX when adding the RMCM user on the CUCM. Just ensure the correct roles.
++ Assign the Monitoring CSS on the Supervisor Phone to contain the Partition of the agent line.
++ Once an agent is in the TALKING state, perform the Silent Monitoring.
++ Please ensure that the agent phone and Supervisor Phone are compatible for Finesse using the following compatibility matrix:
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_10.5%281%29
Section IP Phones for Cisco Finesse.
Considerations For Silent Monitoring:
++ The Supervisor Needs to login to Finesse and must be in NOT READY State.
++ The Agent needs to login to Finesse and must be on an active call – TALKING State
++ The Supervisor will have the Silent Monitoring Button Visible only when he selects an Agent in TALKING State.
++ The Finesse with UCCX uses the native Call Recording and Monitoring functionality of the Call manager.
++ Link for Configuration on Call manager:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm
++ Following is the guide for UCCX that talks about unsupported and supported configurations for agent phones:
++ The IPCC Extension needs to be unique and must not be shared across devices or line groups.
Troubleshoot:(After the above config is verified)
Step 1: Confirm if the Finesse Desktop client session is behaving fine
Step 2: Is the request to start Silent Monitoring coming to CCX Engine from Finesse Server?
88046 – BIB not configured.
88048 – Monitoring Settings not configured
88056 – Monitoring Already in progress.
Deepak
10-11-2015 08:19 AM
Thank you very much Deepak for detailed instructions. I will try this out and let you know.
11-03-2017 12:04 PM
Hey Deepak,
This was a great write up that I followed completely and got it working almost 100%. There's a weird issue I'm seeing though which I'm wondering if you have any information on.
The supervisor can Silent Monitor on an 8851 no problem but when I switch their IPCC Extension and RmCm controlled device to an IP Communicator they cannot hear anything, just dead air.
Then I did something for an experiment that I know is wrong but wanted to see if it would work by adding the IPCC extension to the 8851 even though it wasn't the RmCm controlled device and if the Supervisor puts the Monitor on hold on the IP Communicator then retrieve it from the 8851 they can hear it just fine.
Any thoughts on this issue?
Matt
11-07-2017 08:39 AM
Hi There,
Just moved to Finesse and I have the same issue, only dead air when monitoring the IP communicators. We are running version 10.6 on the CCX and version 8.6.3.0 & 8.6.6.6 on the IPC's
Any help, would be much appriciated.
Thx
Steen,
10-10-2015 08:47 PM
did you ever get this resolved? Can you share some information? I am having same problems.
02-03-2017 06:03 AM
Resolution:
Vaijanath Sonvane
10-10-2018 01:14 PM
Very Helpful. Thank you.
09-19-2023 12:09 AM - edited 09-19-2023 12:09 AM
Dear Sonvane,
I re-checked the above mentioned settings which were configured correctly (built in bridge> (on) in the supervisor phone and also it was enable in clusterwide parameters section (on), but in Line 1 on Device SEP00451D6xxxx the following settings are configured;
Recording option*: automatic call recording enable
Recording Profile: AQM Recording
Recording Media source *: Phone Preferred
Monitoring calling search space: CSS-Recording
but still I receive the following error message when the supervisor click on the Live Monitor button (we have this problem only for home based agents using CIPC through VPN).
Waiting for any further instruction in this regard.
Thanks in advance,
09-19-2023 04:27 AM
You didn't say what the error was that you are receiving, nor the platform (CCX, CCE, etc.).
09-19-2023 07:24 AM
