Hi everyone i'm having issues with caller ID here in mexico, my telephone provider is Telmex and i can figure out the way to get the called Id working. Can you help me with this? I have selected european Fsk in the spa400 and in some calls the caller...
Update:Looks like there's a discrepancy from one Version of Xterm to another, the commands are interpreted differently. This can be closed, thank you very much I'm trying to configure a CBS350 24T-4X with a pre written config file, it's not the first...
Hello Cisco communityWe currently utilize the Cisco telepresence touch 10 in our conference rooms. This device seems to work well in smaller rooms but in our large conference room, we would like to add a couple microphones so that people sitting far ...
Hello,I am new to networking and have been unable to pin point the source of the issue. We have two CBS 250 devices that have been acting odd lately. 2-4 times a week the management interface would disconnect for about 5-20 mins. I've compared config...
l getting error on ap is flashing red green and blue and my switch is cisco small business SF300-POE And no wifi this ap is covert to me newest version sill flashing red green blue
Cisco 3650 uplink to router is going into sfp port 1/1/4 and shows operational status down ?I have it set as a a trunk port on the 3650 and is connected to a 10 gb SFP port on a tp-link switch which shows it is connected The port is obviously connect...
I have my config attached. Essentially I have a VLAN I have been using for awhile: 192.168.6.0 I am trying to add an additional VLAN in the form of: 192.168.20.0I have mirrored the config as close as I can in order to get it all working, but it refus...
I've recently deployed a 2x CBS350-48FP-4X stack and the CPU is pinned at 100% during production hours. There's a 2x CBS350-24FP-4X stack in the same location at the access layer with an almost identical config and that thing is fine.This problem exi...
Dear all I have a new cbw150ax-s unk access point. I have set a captive portal and test AAA authen with external radius. All work fine but there is no accounting send to my radius server. So I need to access ssh to use terminal and enable radius acco...
Hello, I am looking at Catalyst 1000 - C1000-24P-4X-L In datasheet it is written: "Support both IEEE 802.3af PoE and IEEE 802.3at PoE+; 30W for any 6 ports or 15W for any 13 ports; PoE power budget: 195W" This means: A) It has 13 fixed POE ports(e.g...
Which is an advantage of Cloud over on-premises deployment ?- Cloud deployments provide a better user experience across world regions, whereas on-premises deployments depend upon region-specific conditions.- Cloud deployments must include automation...
buen dia tengo un problema con un switch cisco sf350Cisco SF350 24 PportsSoftware InformationFirmware Version (Active Image): 2.5.8.12Firmware Version (Non-active): 2.5.0.83El problema es que en mi servidor dhcp a cada minuto el switch esta solicitan...
Is it possible to recover a password from RV345 without a factory reset? As far as I can tell our password was updated when it last expired but wasn't updated in any documentation we have.
I have a CBS250 that wont power and still under warranty. I called cisco support and they told me I need to finish setting up my profile. However, I cant get access to main site and when I log in, it just kicks me out to main page. can someone help p...
We had some changes recently and have inherited an aging campus infrastructure. Being primarily from service provider background, we are slowly exploring the Campus ecosystem. Does it make sense to use the same devices used in SP for Campus? Core and...
