HelloI can seen that ATA-186 has reached End of sale and replaced by ATA-187 but I can see only ATA-187-I1 version, is there a I2 version ?Thank for answerregards
Hello, I'm currently running for one voice project. Gateway and call manager are up and running. I can make call out by using soft phone. But I have a problem with IP Phone registration with my call manager. It shows Configuration IP and nothing came...
Hello!I'm trying to get inbound calling to work to a CUCME system over a SIP trunk. I've been working with the SIP trunk provider, but all we get as a clue to what is wrong is the error message "SIP/2.0 400 Bad Request - 'Invalid Host'." The router ...
I have been asked to setup an office with multi tenants. Using Business editon 8.0, I am looking at a way for each company to have their own directory and not see any of the other users outside their own.There is'nt going to be a master AD server tha...
After upgrading from CM 5.1 to 6.1.3 1000-16, wehad a problem on Outbound calls. If we dial the number we receive a Fast Busy tone. But ifwe 'redial' it, pressing the 'REDIAL' button, everything works fine. We tried to reloadthe VG (Cisco 2811 with 1...
Just taking a look at CUCMBE v8.x and I'm a bit puzzled by the licensing.From what I can tell, the base system comes with 50 seats. Does this give me ability to have 50 users with phone/voicemail or do I need to purchase additional licenses to enable...
Is there a way to run a report to discover which phone may not be runningthe default firmware.
Hello to ALL,I am looking for a document to use witn the customer for a migration PBX to Cisco ip telephony UC520, please Could anyone have it?Thanks a lot
Im experiencing echo across vg224 ports. any idea what can be the cause and how to eliminate.Thanks
Hi,I have an router 2901 configure as a CME. I'm using a SIP trunk for connecto to my voice service provider.This is Version 15.1(2)T1 of the router.When a make a call from an internal IP Phone there is a silence time of about 10 or 12 seconds then t...
Hello,I want to set a greeting of closing on the CallManager with unity, Can someone help me thanks a lot.Aubert.
Hi guys,I met a problem, one of our guest has a cucm7.0 , recently they told me telephone of office can be count by bill server ,BUT all guestroom telephone is free! cucm didn't sent cdr record to the bill server. office and guestroom use different C...
Is there any problem to configure a branch router as NTP server and at the same time configure it to get NTP referance from another NTP server at main site?
Hi,I have one issues with extension mobility, I upgrade a cluster from 7.1.3 to 8.0.3 but I face license issues so I sweptback to old version which is 7.1.3 every thing working find except extension mobility I am trying to press the services button b...
hi all,My senario is:I'm setting up CISCO VoIP from the ground, server is not ready yet.and I received 2 reused 7961 IP Phone, when I try to setup the phone I found can't change settings.so, I resetted it.... but I really don't know on cisco ip phone...
Subject | Author | Posted |
07-23-2025 12:10 PM | ||
07-16-2025 12:00 PM | ||
07-15-2025 06:51 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM |
User | Count |
11 | |
2 | |
2 | |
1 | |
1 |
