Network Management
Labels
This is after deleting the previously stored key from/home/myid/.ssh/known_hosts.debug1: sending SSH2_MSG_KEXDH_INITdebug1: expecting SSH2_MSG_KEXDH_REPLYdebug3: check_host_in_hostfile: filename /home/myid/.ssh/known_hostsdebug3: check_host_in_hostfi...
yjdabear by VIP Alumni
  • 13446 Views
  • 9 replies
Resolved! Ftd osp/bgp
Hello, am abit new to Firepower configuration.. We have two ftd instances, one as campus and another as perimeter, both managed from fmc. The the two instances share routes via ospf peering, and bgp retribution also configured.The problem am facing i...
Dkiptoo by Level 1
  • 853 Views
  • 8 replies
 Someone please help me with this Please. I tried configurations and try pinging from one PC to another PC in another vlan but "request timeout". I'm confused what to do firstly.
RixSnoopy by Level 1
  • 320 Views
  • 6 replies
Hallo, I have problem with my website access, i my case i can access my website outside my network. but can't access my website in my network. i use IIS as my webserver and cisco 2900 as my router. i have setup NatLoopkback,hairPin nat and DNS intern...
gamu by Level 1
  • 231 Views
  • 2 replies
Dears,        I have a customer who has an issue with voice between two branches; the WAN link is utilized at peak hours of the day.        I need a full QOS conf end-to-end from the access switch to the WAN router        Does anyone have a document ...
Hello,New to Firepower configuration.  My inside wired network is working fine.  It is vlan 1 and pretty much default configuration.  I'm trying to add a new subnet to the inside for a wireless network. I connect my firepower to a router on another i...
kenhagen by Level 1
  • 187 Views
  • 2 replies
I am a novice network guy.  If I have missed something obvious, please let me know. I have a N520-20G4Z-A and using SFPs only in ports 4,5,6, and 7 - Port 7 won't come up.  There are no other connections to the router.  The four of the ports are conf...
