Network Management
Insider User Research program
Labels
If you look at the tacacs profile as shown in the picture, there are custom characteristics I wonder how this works. In the case of other banders, I understand that tacacs are linked using these attributes If you add a value here, compare it with the...
CCC3 by Level 1
  • 33 Views
  • 0 replies
Hello everyone,Here i have two uplink from my main core switch which is connected to Main-R.i would like to utilize both uplink same time for different network Eg:MGMT network use Service Provider as a Uplink (192.168.3.2)DATA network use Main-R as a...
I am working on connecting some upgraded circuits from our ISP and am having a hard time navigating the dual links that were ordered. I'm working with Catalyst 9300s running 17.5 and am trying to connect both links through my routers. They are dual 6...
dbronco by Level 1
  • 245 Views
  • 7 replies
Resolved! IOS IPv6 CoPP
I'm trying to configure IPv6 access for a BGP session and I want to control this through CoPP, to have more control plane security on my Cisco router with IOS, I did an initial configuration and it continues to accept connections from IPs that I didn...
I am  working on a eem script and struggling to display a script output line by line on a syslog. It show mab all sum and the result is usually like this : Interface Client Mac Authen Status Gi1/0/1 aaaa.bbbb.cccc SUCCESS Tw2/0/2 cccc.dddd.eeee FAILE...
Tania S by Level 1
  • 112 Views
  • 1 replies
Hi everyone,To all engineers who love cisco CLI, what is the possible solution to this below errorKey exchange failed.No compatible MAC. The server supports these MACs: hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sh...
amutua17 by Level 1
  • 1938 Views
  • 4 replies
