How can I obtain and download configuration backups of the C9200, C9300, C9500, ISR, and other network components through DNA, and download them automatically?
The content you are looking for has been archived. View related content below.
I have a TRIPP-LITE media converter Model: N785-H01-SFP that suddenly stopped working on my C9300-24S after I have updated from 17.6.5 to 17.9.4a. The steps I have taken to trouble shoot are as follow:- swapped the sfp on the switch and media convert...
Hello Professionals,Could you please see my EEM script is alright? - Goal: Want to get 'show ip arp' results everyday 11:00am and send it to tftp server. - EEM Script: event manager applet IPARP_LOG event timer cron cron-entry "0 11 * * *" maxrun ...
Hi, Can anyone suggest the configuration the below topology.
Hi all,this ist a part of our switch port config on a C9300 with an IOSXE 17.9.X:+++interface GigabitEthernet1/0/7description RADIUS Portswitchport access vlan XYswitchport mode accessauthentication priority dot1x mab+++now due to some internal issue...
Hi Everyone,I'm interested in streaming telemetry using GRPC to our organization's ELK environment.Can you share with me the recommended GRPC Collector - I saw a couple of solutions such as1. Pipeline2. Telegraf3. pmacct4. nifiI appreciate any help y...
Hello Everyone,I'm novice to networking. And below is the requirement I'm trying to figure out. Any leads would be greatly appreciated"You are working as an IT architect for a new startup business that grew faster than expected. they expanded to oper...
Hi,I have a simple EEM applet which triggers a syslog message whenever anyone enters enable mode (to be exactly it triggers a syslog message whenever anyone types ena on the cli, so if anyone knows a better way to do it, I would be glad to know how)....
Hi everyone,To all engineers who love cisco CLI, what is the possible solution to this below errorKey exchange failed.No compatible MAC. The server supports these MACs: hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sh...
At my new job, I was told RADIUS hasn't functioned for over a year. I wiped the RADIUS server settings and started from scratch. I'm happy to say, after going thru every cisco device, ALMOST all devices now login via RADIUS flawlessly. There are t...
Hi everyone, I'd like to ask a quick question. I would like to migrate int-vlan and routes from Cisco Catalyst 9500 (17.03.04) to a next generation firewall. I am making sure that the true sizing of sessions, throughput, connection per second etc.. W...
I have configured the netflow on my cisco ISR 4451 management interface but I am not able to collect data on my NMS server. Also i have given static route to my NMS server Source 10.146.96.101Destination (Collector): 10.146.104.35UDP Port :5111 Below...
Hi I have a EEM script where I use the '$_cli_result' command to display it in the output. I'm not entirely sure if this would be saving to the flash and then the $_cli_result command is pulling from there. I don't think it would save to flash but I'...
Hello,I've got a couple of Catalyst switches that are accessed by the admins via SSH.For security reasons I like to change their login method from password to public key authentication.In addition to the admin users, I have a few technical user accou...
Hi So i have an issue that is frustrating me, i have been creating a lab using SD WAN, I have the vEdge's set up i now have an issue with the cEdge, basically i cannot transfer the certificate from Ubuntu to the CSR, I am not sure if this is a cisco ...
Subject | Author | Posted |
04-23-2024 05:52 PM | ||
04-23-2024 12:20 AM | ||
04-16-2024 04:45 AM | ||
04-16-2024 01:33 AM | ||
04-13-2024 12:00 PM |
User | Count |
3 | |
3 | |
2 | |
2 | |
1 |
