Network Security
Engage with peers and experts on network security topics such as FTD, FMC, FDM, CDO and ASA.
“Join
Labels
Hi Fellas,I have a question, regarding how the ASA with IPS module or Firepower with intrusion policy is able to check VPN traffic.The traffic is coming from a L2L tunnel and does a U turn pointing to a VTI so the traffic never pass through the devic...
cmarin by Level 1
  • 281 Views
  • 4 replies
Hello,we've a Cisco Firepower 2110 Threat Defense and we're going to move to M365.There's a large set of applications which I can setup in the firewall rules.Is there a best practise guide to setup our Firepower for the inbound and outbound rules? Ou...
Marco87 by Level 1
  • 127 Views
  • 3 replies
This might be a dumb question but how would you set up the ASA firewall 1000 without internet connection? I have a switch that connects to it. I think I can console into it with putty but isnt there a gui ?
Hi, Team we had an issue with the ASA failover  the one should show standby , but it show failed State Last Failure Reason Date/TimeThis host - Secondary Active NoneOther host - Primary Failed Ifc Failure  inside: Failed could you help to undertand ...
Hello, I’m not at all familiar with any of the intricacies in any way and really am just requesting a simple version answer for this please. I just want to know which asa image file I need to use and what adsm image to use in order for the firepower ...
My understanding is that URL feeds in FirePower SI are updated dynamically and take effect w/o having to do a policy deploy to the FTD. Does the same apply to custom URL feeds used in an ACP rule? My idea would be to create a custom URL feed on a loc...
tato386 by Level 6
  • 247 Views
  • 8 replies
