VPN
Cisco CyberSecurity
Labels
Dear All,In one of our IPSEC VPN , We are having issues in FTP, when client is trying to access a FTP server in AWS cloud. while having captures and system trace we found that at snort ,the route lookup is not taking correct egress zone instead it ta...
Looking for some clarity please around the failover of a s2s VPN terminated on a FTD 9300 Cluster.Cisco Secure Firewall Management Center Device Configuration Guide, 7.2 - Clustering for the Firepower 4100/9300 [Cisco Secure Firewall Management Cente...
Hello Team,I have a topology as below; Site A is the primary site, site B is the secondary site.I have an afrinic IP of 110.110.110.0/24.I use 110.110.110.10 as my local peer to ipsec vpn clients.On ftds,on both sites i use the same afrinic IP; 110.1...
fmugambi by Spotlight
  • 88 Views
  • 0 replies
I am trying to install the openssl tool detailed in this guide - https://www.linkedin.com/pulse/anyconnect-ftd-pkcs12-openssl-matt-albrecht/I have the openssl-3.2.3.tar file. But not sure what to do next, I have a Windows machine..
I'm working on an ASAv deployed in Azure and had a working AnyConnect configuration using LDAP to a DC in Azure.  I tried to setup SAML with Azure AD today and while it appears to be partially working, users are unable to connect.  This is my configu...
We have a user that keeps receiving the error stating an Invalid PSK when connecting to their home network. They are 100% sure they are typing it correctly. The user can connect the first time after adding The network via NAM. If the reboot or connec...
Hi guys!I'm pretty new to Cisco routers and learning alot from configuring a Firepower 1010. At the moment I can't use CLI as the router is in another place. I would benefit from doing this through ASDM since I'm using VPN to get to the server which ...
Hello, I would like to configure for Cisco Anyconnect DHCP Address Assignment from Windows DHCP Server. I Use this Manuals (https://www.cisco.com/c/en/us/support/docs/security/anyconnect-secure-mobility-client/215854-configure-anyconnect-vpn-client-o...
I have a fairly simple VPN setup with two physical locations but I can't seen to get it working.Each location has the same router C1111-4PThe first location has subnet 192.168.0.0 and the second location has subnet 192.168.3.0I have a zone-based fire...
Sent by you:Cisco Secure Client icon missing after the upgrade. Once we have completed the upgrade manually for pilot test purpose, the favicon and shortcut are missing.We have to type ' Cisco Secure Client' on windows search bar for the first time. ...
Sabu-Nair by Level 1
  • 132 Views
  • 1 replies
Hello,We have Cisco and HP router forming IPsec tunnel, we can see traffic flowing, but it happens that traffic stuck in IPsec, however ISAKMP and Tunnel is UPAttached my configuration on Cisco and HP side, I will also post errors below from debug on...
Hey Everyone!I came across a problem with assigning addresses for VPN users via an external DHCP windows server 2016 instead of the local Address-pool.I specified the dhcp server in the profile settings and the network range in the group policy.I als...
jakmor by Level 1
  • 2553 Views
  • 31 replies
  • 1 Helpful votes
Dear Guys,  Is it support following scenario: Cisco FTD with configured Remote Access VPN, authentication and authorization via Cisco ISE and MFA from Azure? From client perspective: Client connect via AnyConnect to FTD, receive prompts for username ...
mikiNet by Level 1
  • 194 Views
  • 1 replies
