Routing
Labels
Hello office working well, i cant entry ssh via private address, when i try connect via global address i coudn't i will start trublishooting everythisg is good, i Guess ISP will block ssh incomming or any filter to my private ip address, Thanks in ad...
Mlex1 by Spotlight
  • 287 Views
  • 16 replies
Hello, Team,I want to connect the PCs in VLAN 10 to the PCs in VLAN 40 through two Layer 3 switches on which I have configured EtherChannel 3. But the communication fails.Please find the architecture in the attached image (at the bottom of the page)....
taonrez by Level 1
  • 319 Views
  • 11 replies
  • 1 Helpful votes
Hello,I have a question on Cisco 8000V router.Does the Cisco 8000v Advanced license include DMVPN functionality?Also, are there any limitations regarding site-to-site VPNs?Does it support firewalling features, such as NGFW capabilities?Additionally, ...
divas80 by Level 1
  • 287 Views
  • 9 replies
Good day All,I have 2 N9K-C93108TC-FX3P running ospf (rtrA and rtrB) right now the way ospf is working is that all the routes are currently going over rtrB.  I have 2 subnets 10.4.1.0/2410.4.2.0/24I don't want these 2 to go over rtrB but instead need...
wgranada by Level 1
  • 173 Views
  • 9 replies
Hey everyone - had a question about dot1q tunnel. I am trying to wrap my head around it for a customer handoff on a 3560 device, which hands off on a l2vpn between two nodes on my MPLS. The one end is at a branch of the customers, we are hoping to ad...
Hi all,One of the two ISR4431 started to boot into errors after power outage. I can enter ROMMON, able to boot many different IOSes (including external TFTP download via Gi0 interface), but all of them got stuck & reboot with the messages below (more...
Hello,I have two routers connected with multiple switchs beetween.I'm encountering a problem for forming adjencies in OSPF.I don't understand something, all my interfaces are with 1500 mtu value. But when i put a link beetween two switchs in trunk mo...
Hi, what could be the reason ?Last reset cause: Unrecoverable ErrorC1117-4PWA platform with 4194304 Kbytes of main memory........no valid BOOT image foundFinal autoboot attempt from default boot device...Located pnp-tech-time#Unsupported package head...
Hi,I'm working on a C3945e with a EHWIC-VA-DSL-M installed. It's configured as an Ethernet Interface interface Ethernet0/2/0 description C3945e-1/Centurylink VDSL2 link ip address (PUBLIC_IP_HERE) 255.255.255.128 ip flow ingress ip nat outside i...
Tuc by Level 1
  • 298 Views
  • 10 replies
The documentation states that unencrypted throughput is unthrottled and encrypted throughput is controlled by license. What does encrypted throughput mean in terms of the 8200 throughput license restriction? I've read the documentation and I'm still ...
emuman100 by Level 1
  • 516 Views
  • 8 replies
