Routing
Don't miss this Cisco Catalyst 8000 offer
Labels
Finding accurate answers to your questions and issues is always gratifying, but what if these answers are shared globally across different languages? The Cisco Community team has been working on a proof of concept (PoC) to take Accepted Solutions in...
Kelli Glass by Community Manager
  • 10291 Views
  • 7 replies
  • 16 Helpful votes
Hi Guys, i had this problem for 8 hours now and can't seem to get it cracked... after i input the command copy xmodem: flash:c2960-lanbasek9-mz.152-7.e9.binand using the SecureCRT going to Transfer > send xmodem I get this and after that nothing happ...
Sorry, I am reposting because I want the community to see this because where I previously posted, the thread shows resolved already.I have an ASR 10g interface that is connected to a native vlan1 in a HP switching fabric (8 switches) for databases (i...
jroy777 by Level 1
  • 104 Views
  • 2 replies
  • 1 Helpful votes
We're trying to form an encrypted IPsec/L2TPv3 tunnel between two 2901 routers running IOS 15.4+.  When we try to connect, we can see that the IPsec tunnel is up and that the xconnect session is up but no L2 traffic is traversing the tunnel.  We are ...
earsenov1 by Level 1
  • 2683 Views
  • 4 replies
Hello everyone!We have ASR1001x with fullview and ipsec tunnels. We use local policy to forward packets from PA addresses to their respective gateways. When the traffic load is high PBR stop working and the router starts using cef, when there is litt...
shados by Level 1
  • 180 Views
  • 13 replies
Hello, I know very little about configuring cisco hardware and need some help..... we are currently running an 1800 router and I obtained a new to me 1921 router and would like to replace the 1800 router with the newer one, I managed to get it factor...
cwasilak by Level 1
  • 254 Views
  • 14 replies
hi guys thanks for your suggestions in advancei just reconsidered my whole message. after trying some things. i think i need to set up acl but i'm far from good at it.what would be the ip access-list extended or access-list lines that'd allow me to h...
gabecz by Level 1
  • 205 Views
  • 4 replies
We have just installed an ASR1001-x router and need to suport 3 vlans at present is there any information/documentation on how to do this  At present we have three sub-interfaces on Physical Port G0/0/3 - namely 0/0/3.3, 0/0/3.4 and 0/0/3.5how do i c...
RBrien by Level 1
  • 4392 Views
  • 3 replies
Hi, we have a WAN and VSAT connection to one of the site. WAN is primary and VSAT is secondary link.We have dedicated router for WAN and VSAT. VSAT link is connected to one of the LAN access switch.Could you please help me, what kind of configuration...
inhamit by Level 1
  • 282 Views
  • 11 replies
Hi,We have mGRE DMVPN tunnle between one Hub and 7 Spokes. Other 6 Spokes are working fine but one Spoke is not connecting to Hub.Spoke shows DMVPN on IKE state (tunnle is not working) and Hub is not adding nhrp entry in table.Spoke DMVPN TunnelPleas...
INBKIT_0-1713981579965.png INBKIT_3-1713982713738.png INBKIT_4-1713982931986.png INBKIT_5-1713983001947.png
INBK-IT by Level 1
  • 191 Views
  • 7 replies
