Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2964 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4553 Views
  • 1 replies
  • 16 Helpful votes
I have a SG300-10Mp with 8 WAP attached, the switch is behind a router and two additional switches. I all comes up and I get wireless Internet at all WAP, but all of a sudden it stops working, the Internet is not longer accessible and its connected t...
Resolved! Linksys SFE2010
I have a Cisco SFE2010 48-port 10/100 Ethernet Switch and I don´t see the options to configure Layer 3. It seems that my devide is only a Layer 2 device. I don´t know why because Data Sheet says the it has Layer 3 propertiesRegardsCarlos
Hi, By recommendations of a person in cisco support chat I've uploaded SRW2016 firmware to the switch via tftp whithout uploading first the bootloader. When the switch restarted, I was unable to get a connection by ip address. So I connected the swit...
Resolved! Slow InterVLAN
Hello,I have configured  2 VLAN on a SRW 2024.I have just one switch.I have a very slow connection between the 2 VLAN (100Ko/s)And I have good connection  in the same the same VLAN (12 Mo/s)So is it a problem of configuration ? and what I have to do ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
