Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I just purchased 4 WAP571 APs to use as a cluster, 3 of them are working great, when the 4th is joined to the cluster any client that connects to it is unable to get a IP address from the DHCP server. If I reconfigure this AP to not be part of the c...
Hi,I hope someone can help I've been struggling to find an answer to this.We Bought 3x WAP551's recently but are having nothing but hassle with them. Half our devices won't connect or show low/weak signal even when only sat a few meters away. Other d...
I had 3 Cisco WAP571E Wireless Units Clustered from 2016 and working fine. One of the units failed (still looking to get that resolved), but couldn't wait and added a new 3rd unit just purchased. Updated the firmware of all to the most recent (1.0.2....
The website for the WAP125 lists the latest release as 1.0.0.7Hitting the link for All Releases shows 1.0.0.7 as the latest release. However if you expand the 1.0 release section you see 1.0.1.5 listed from 30-Jul-2018 which is newer than 1.0.0.7 05-...
We have several WAP561 devices repeating the wireless throughout the office. Everything works fine with the existing 3 WAP561 devices we have running. HOWEVER, When I plug in a new WAP561 device and add it to an existing cluster (single point setup) ...
I just upgraded 7 WAP571s to the new firmware from 1.0.2.6. While it works, I did notice some problems. I list them below. 1) Administration a) Time i) Set for UTC-06:00 USA (Central) ii) Current Time display shows 5 hours ahead (current U...
I have setup Cisco Aironet 1815i with Cisco wireless app for provisioning then I can connect to SSID normally, But can't access to mobility express, I try to connect with ssh with DHCP IP of AP (I don't know why this IP difference with IP Managemen...
Hello Cisco experts,I have an Access Point Cisco AP541N, working great, except that every 1 or 2 weeks, clients cannot connect anymore to it. I need to reboot it.I recently updated the firmware to the latest version (AP541N-K9-2.0(0)), but that did...
WAP561 Access Point and external Radius Authentication (Windows Server NPAS)Hi,I've troubles on configuring Radius Authentication AP: Cisco WAP561Radius Server: (Windows Server 2016 - NPAS)I've configured an Access Point Network with Security (WPA En...
Hi, we got a cluster of 3 Ap Cisco WAP371. Cluster doesn't work and web management show a red message of error.Firmware 1.3.0.6. Already tried to upgrade firmware and factory reset (and new configuration) without get solved. AP using POE original ada...
Hi,My Cisco WAP 321 Access Point Does Not Start.The Power LED blinks slowly Green. Access point is available on network.No Wifi signal is present.I don't have Acces to recovery mode.How do I restore my access point?Best Regards.Fabrice.
Hi,our WAP581 periodically stops working: connected devices report "no internet" and web-based utility login page is unreachable. Unplugging and replugging it makes it work again for 20~50 days.At the time the AP stops working hostapd starts reportin...
Hi Guys,I am currently experiencing an issue with a brand new Cisco WAP571 access point. Below is the errors on the access point, when a users tries to authenticate with their AD credentials via radius:Apr 4 2019 12:20:57debughostage[23954]station: 4...
Hi,I am currently working on creating a guest login. I am using WAP 571 Cisco device. I created the SSID with guest authentication.i am having issues.1. When the user connect with guest-wifi it should redirect to my custom page in where i welcome the...
I putting together an IoT network diagram that uses a meshed network consisting of Cisco Aironet 1570 Access Points in bridge mode. I cannot find the correct Visio stencils. Can you please assist?
