Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 690 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2892 Views
  • 1 replies
  • 5 Helpful votes
Hi,i have a few problems with a CBW240AC in standalone mode, SW 10.9.1.0:- How can i change the password complexity rules?- How can i set "public" as a SNMP community and limti access via an ACL?- How can i access the console? I found a command "cli-...
maweigel by Level 1
  • 849 Views
  • 6 replies
Hi everyone,We are going to try to use a Cisco Business wireless access point(150AX) with the Cisco Identity Service Engine. Has anyone tried this and is able to share some insights and advice?
Gunnel by Level 1
  • 480 Views
  • 2 replies
I get disconnected and reconnected to my AP's a lot kicking me off the 5GHz network and pushed to the 2.4GHz network. The SSID is the same but split frequency. There is only about 1% interference on the 5GHz network and the 2.4 averages about 20%. I ...
Zbaardsen by Level 1
  • 715 Views
  • 4 replies
I am using 3 AX150 AP in the home environment (700sq.ft with 10-15 clients) and even with the default setting client keeps disconnecting and fails to do seamless roaming with FT enabled with wpa2. With wpa3 roaming doesn't even work.  Earlier I was u...
Dear all,Before one of my APs fails, it keeps rebooting unexpected at a specific time. at 01:20 UTC+8, I noticed my remaining AP also does that. its seems very weird to me as I clearly did not set any automation to my APs to perform self reboot. Luck...
PeterWan by Level 1
  • 927 Views
  • 3 replies
