Smart Net Total Care Portal and Collector Discussions
I uploaded a csv file that included 42 wireless controllers yesterday. It is still in progress, over 24 hours. Could you help me to resolve it? Also, I'd like to know how I can avoid this issue in the future. I did:1. downloaded sample csv.2. filled ...
Hello Team,   I am trying to use "ACI Health Check" in Transactional Assessments through manual upload. It does not allow to upload configs in Json/XML format which was supported earlier. Only available uploaded formats are VSEM/Archieve/Show-tech wh...
sanchroy by Cisco Employee
  • 491 Views
  • 0 replies
Hello, In my CSCP I see the SN of devices, but in the SNTC portal the SN is not showed. - I am use the CSCP version 2.8 - My setting to check duplicate SN is: Settings > Discovery Settings > Serial Number Duplicate Check = Yes26/5000 What could be th...
Hi Team,                 We have a collector where the following is happening ... the Collector (CSPC) performs the Discovery of the equipment, then collects the data from them and finally uploads without any problem ... the problem is reflected spec...
All 6 of my ASA's are showing this error (FAILED: SNAS validated data not available) in the portal. Has something changed in the tool logic that it cannot find the serial number of an ASA or is there a needed config change in the ASA to allow the Col...
Top Solution Authors
