Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 1262 Views
  • 0 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300Hardware Installation Guide - Catalyst 12...
  • 5970 Views
  • 4 replies
  • 17 Helpful votes
I am having a problem with 6941 phones on a SG300.When connected Smartport assignes the native and tagged voice vlan correctly, however the phone connects to the native vlan.  After running a few tests I have found it only happens when the voice vlan...
Hi,I would like to communicate between VLAN, with some access control. I will like gi1/1/2 to be able to communicate with gi1/1/14 but not gi1/1/13.Some background information:VLAN 200gi1/1/1 -> computergi1/1/2-> NTPVLAN 300gi1/1/13 -> computergi1/1/...
reginachh by Level 1
  • 5444 Views
  • 5 replies
Hi,There is a need to replace faster cisco switches.What I have at the minute is:uc500, esw520 and few 500 series switches which have only 2 1Gbit interface, the setup is like that connections from switch is going to cisco phone (vlan 150) and from p...
Hi all,We have a project in which we are using 34 Cisco SG200-18's each with a MGBLX1 (LC Single Mode Fiber) SFP mini-GBIC.All the fiber's come back to one building where we must "bridge" all 34 fiber connections. What hardware should be used to acco...
Resolved! SGE2010P ACL
When I try to apply an ACL to a port on my SGE2010P, I get the following error:Can't bind acl/policy-map to an interface when the security suite is enabled in a per-port modeI don't see an option where I can set the security suite mode.
DJX995 by Level 3
  • 1739 Views
  • 10 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
