Hi i would like to purchase a BE6000s and would like to know the price range of this product. If given in Aud much appreciated
How do you configure FXO ports on a SPA8800 connected to a UC500?
Hi all,We've got a Cisco IP Phone SPA504G that keeps flashing the envelope sign (for voicemail) and the right light is lit on the top of the phone. I've logged into Cisco unity express to check if that particular extension has got any voicemail on it...
I can't get my analgue phone to work thru the Cisco SPA112 ATA box - problem has been ongoing for 2.5 months now.My ISP can access the ATA through their network and assure me everything is configured and working correctly.My wireless (wimax) internet...
Hello,as I have many Problems with the SPA525G2 phones I want to update the Firmware (no Updates are coming from UC320 side) manually.But I searched the whole Internet for Information but nothing works.How do I have to Update the Firmware (on phone, ...
Can we still purchase Cisco support for the UC560? If so, where can we find the SKUs? Thanks
I have hundreds of units in the field with version 1.3.3_015. I was troubleshooting an issue where the ATA was showing all LEDs green, Phone1 and Phone2 being steady but when picking up a phone, no dialtone was present. A reboot fixed it but since I ...
I feel silly asking the question, but I cannot fathom it out.Got the phone on GMT and en-gb, but cannot get dd/mm format. Only seems to be mm/dd.Many thanks in advance R
Hi Guys, I have the following Equipment and scenario:1. Cisco 232D2. Five handsets Cisco SPA 302D. 3. All latest firmware It's extremely annoying when you get a second call on 302D handset. (It starts with a single beep then it goes to a point that ...
Hi,We've just purchased 12 SPA514G phones. Working in an office/factory environment, our last phone system had a speak connected to one of the phones that was then placed on the factory floor for when the paging feature was used. Is this still possib...
Hi,We are having a problem with a phone system we manage. The device is a UC540, which has approximately 16 phones attached. Periodically there are received phone calls which generate a recurring beeping noise. There is nobody calling, it just appear...
Hi, i want to make some changes to my attendant console via a browser, I can connect to my phone and see the console, I have two units , however I just can not work outhow to change them i.e. add more , edit , change order etc.. Is this possible thro...
CUCM installtion halt on be6k installtion, system is asking to restart installtion. how can i restart this CUCM VM, it is now halted after network configuration. Restarting VM is coming to same page.
Does anyone know if the voicemail soft key on the SPA302D can be changed to a different value. It is currently set to (**1)
Hi, I'm running my freePBX with CISCO SPA525G2 phones ( everything is working - intercom, call parking, BLF and paging ); I just added SPA232 with a couple of SPA302 handsets. I'm wondering if I can activate intercom to be used between SPA302 and SP...
