I have a SPA504G phone that has stopped working correctly. When I dial out or someone dials in, they cannot hear me, and I cannot hear them. Can you please suggest some possible solutions? Thank you!
Hi,I'm having a problem trying to log in to SPA 122.When resetting to factory, I begin to configure and after one or two reboots, it begins to deny the default password. I tried on one occasion to change the password but the problem persists. Thanks
Hi guys,I'm from Italy. The ATA when I answer the phone change the hook state to off. The phone rings fine but I can hear nothing and I can hang up. Please help me!
I have the SPA525G wired with the computer hooked into the phone for my internet service. I have 1GHz internet, but not getting that speed at my computer. Is the phone limiting my computer to 100Mbs?
I have a Sp112- Recently installed with ddi number via voipdiscount Everything is working fine or at least seems to be- APART fromWhen there is an incoming call- The phone rings no problem- But the caller receives no ringtone.When you dial the number...
Hello,I have the problem with modulation of transmitted tones.To communication with two device I use the CONTACT ID communication protocol.When I use SPA112 the devices cannot connected.The problem is in modulating DTMF signals.Sending DTMF signal fr...
Hi,I recently updated my Cisco 7940 using firmware P003-8-12-00 for SIP including the SIPDefault.cnf file with correct firmware. But after that whenever the phone boots it looks for several files which are not available. Attached here. Also if I disc...
Hello,I have a Cisco SPA 112.I have configurate one number on line 1 and another number on line 2.I have credit on both numbers to make calls and in information from configuration menu every line look registrated.When i finished the configuration of ...
My ATA is not registering with the PBX system. If I setup a softphone I can get it to register without any issues. The issue seems to be with the ATA specifically. I am running FreePBX ver 13.x (PBXinaFlash) for Raspberry Pi 2. My ATA is running ...
We have a UC560 that has been in production for about 5 years (25-30 phones). Several months ago (July 2016) we purchased a second UC560 on ebay with the idea of having it as a backup in case the existing server has a hardware failure. I upgraded the...
Hello, I just installed my SPA112 i purchased a few years ago. The internet led is green and steady but the power led is continuously blinking. The phone is connected to "Phone 1" and the phone 1 led is off.I have access to the web management but can...
Hi, I need help understanding this situation, a customer of mine having his computer connected through SPA514G. but when he starts video calls like skype or other apps, calls become choppy and scratchy. and when he connects his computer directly to t...
