Hello - I am puzzled by a problem with a UC560. I had the same issue with 8.0 and 8.6. When I use the Auto Attendant, everything works fine for a few days, then I have a problem where callers are hearing the recorded prompts and are given an opportni...
I know i've brought this up to a few individuals already, but thought i'd post it as well:1. CCW does not allow you to put Smartnet on both VCS and Communicaitons Manager under the BE6K bundle. It's one or the other.2. CCW does not allow you to matc...
Hi,I like to say, assign top right 1st button as an outgoing fxo line(s). Then assign right 2nd button as an outgoing sip line. This will allow the users to select the lines of their choosing.Is there a way to create your own dial plan? ie: press 5 f...
I am trying to connect to two SPA525G2 Cisco IP Phones to upgrade the firmware. Currently, they have firmware v7.4.8. The hardware version is 2.1.0.I have tried these steps:1) set PC with Configuration Assistant to fixed IP and disconnect from LAN2...
I was setting up some remote 7900 and spa50x phones using a vpn to connect back to the main site.. from what i saw on the remote site routers, i got the impression that the 7900 phones do qos tagging for dscp EF, but i saw no such marking on phone t...
My company is about to deploy approximately 70 SPA122's and I'm looking for everyones opinions on the stability and operation of SPA122 firmware v1.2.1-004.
Hi,I´m trying to configure an YX Wireless as a SIP Trunk for the UC540. I can receive calls, but i can´t make any call, maybe someone who has already configure this can give some advice.Any help will be appreciate.Thanks.
Following the directions in the following post, I was able to get remote phones working with a UC560 and SA520W over a VPN connection.https://supportforums.cisco.com/message/3734746#3734746The issue I am coming across is that after about 45 minutes, ...
If the voicemail capacity on UC320W is 30 min per individual mailbox and there are 24 users, is it possible to have 6 users and use the entire 720 mins?Thanks! Aaron
Hello,I am looking for an SPA 3102 expert out there. There's very few and far in between so any help will be appreciated.I am a physician and I work with Doctors Without Borders travelling around the globe to very remote areas - so I've developed a r...
Hi Friends,I was looking through posts here in the SMB commuity, the SWP 8.6 for UC5xx, the RN for CCA 3.2.1, and the OLH for CCA 3.2.1, and found a nice thread that will help anyone wanting to get a 9951 or 9971 SIP phone to operate on the UC5xx aft...
Hi,A few days ago, I ran telephony wizard on a new UC560 for the first time. The wizard stopped with an error ("Exception: Null" ...) at 55%. Although, telephony worked as intended, so I proceeded configuring until I realised the wizard broke the CUE...
Hello,Is there a way to allow a non-admin rights into the configuration assistant, so that they can only make certain changes.An example would be: Someone from a communications department wants to make changes to the auto attendant message.Thank you...
