Collaboration
Engage with your peers and Cisco about collaboration products such as contact center, IP telephony, collaboration applications and telepresence.
Navigation banner_4
Browse the Community
Accessories
Please post here your questions for Headsets, Cameras and any other Cisco Accessories
Hybrid Work
The place to discuss the new Hybrid Work offers for work from Home, work from Office and Software Of...
Activity in Collaboration
CUCM CDR Filtering
One of my clients asking these questions:  1. Which cause codes are categorized as abandoned calls?2. Which cause codes represent human error? Many of the failures on my network are due to users misdialing; for example, some dial only eight digits in...
Cisco PCCE 15.0 Upgrade
We are running the PCCE 2K model with Windows & SQL 2019. We are now planning to upgrade only Cisco Applications to 15.0, without an OS/SQL change.The customer wants to change the OS/SQL after a few months. According to the Cisco document, this appro...
Webex Contact Center - Basic Webex Connect flow to AI Agent
Hello,Just starting our journey with Webex Contact Center and just got the hang of bacis with the Voice Channel flows, we are now getting into the digital channels and trying to figure out the Webex Connect Flows.We currently got the Apple Business M...
Ted S by Level 3
  • 79 Views
  • 0 replies
Multi Camera Director Mode in MTR
Hello Guys, We have Quad Camera and PTZ4K connected to Coded EQ. I want to enable Multi camera director. However, I am not able to select Multi Camera Director Mode  on Cisco Touch Panle. Device is registered to MTR. Attaching video and document whic...
aniket-raut by Frequent Visitor
  • 5300 Views
  • 11 replies
dial-peer voice, prefix 9 - VG320 CLI
I would like to use the "Prefix" command in a dial-peer on my VG320I'm using the configuration below, but the Prefix 9 doesn't seem to be working.If I dial a 4-digit extension from this port, the call goes right through.I would have thought I didn't ...
kbeaton by Level 5
  • 179 Views
  • 3 replies
Webex desk pro screen does not turn on
Hi, my Webex screen does not turn on.it was working, then I wanted to do a reboot. I used the button to shut it off. After that I used the button to turn it on. I see the screen going from totally black to dark grey. The led is blinking. After a whil...
mark2a by Community Member
  • 237 Views
  • 3 replies
Outbound dialer diallist column for ICM script routing
HelloCan we use a Dial List column for ICM script routing?For example, based on a Dial List column named "Language", can we play language-specific IVR prompts in an outbound campaign?If a phone number in the Dial List has the Language value set to En...
Install CUCM device package
Hello,We have two CUCM VM machines "Subscriber & Publisher" version 12.5.1.18901-1 and need to install device package "cmterm-devicepack12.5.1.22212-1.cop" to adding 9800 phones. Appreciate your support to know to install it and should installed it a...
Demystifying SIP Call-ID and Tag Fields
In every protocol that creates and modifies objects, header fields, or body content, it is crucial to distinguish one object or message from another. This brings to mind the SIP signaling protocol, and the typical example of such an object is the SIP...
Meddane by VIP
  • 130 Views
  • 0 replies
