Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have 4x AP-541N clustered on my network, connected via Ethernet to a network switch. I think I have experienced most of the problems previous posters have mentioned. Can a member of Cisco support provide an update regarding degradation of service...
Hi,I have got 24 port Poe SMB pro 500 switch. Now I want to have a guest wireless access in a small office with 20 people. With this wireless access point only guest will be able to browse the internet. What would be the cheapest good solution to hav...
Our WAP4410N AP Version 2 running on the latest 2.0.2.5 firmware is troublesome as well.As far as Windows clients running on Intel 1000 wireless cards on Enterprise 7, accessing the WAP is of no issue.The issues that exist are with Nix wireless drive...
We have a WDS connection between two AP541 access points, where one AP is connected to a SA540 with cable. The AP in the other end of the WDS does just act as a repeater, broadcasting using the same SSID and channel with WPA-PSK, as the cabled AP. Fo...
Question for choosing worless router for small business about 30 employeesHow do I choose the right wireless router for small business about 30 employees?Please let me know if there is any recommendation.
We have installed Three WAP4410N in a G+1 Villa (Two in Ground Flooor and One in First Floor) to cover the entire villa with wifi network. We created Two SSID (DATA and VOICE). The SSID DATA is Visiable to all and SSID VOICE is HIDDEN. We connect Fou...
Hello,I'm implementing a new network for a school that I'm volunteering for. The bulk of the classrooms are located about 100 yards away from the main office (accross a parking lot). My plan was to have our internet access and file server located i...
I would like to see IPv6 DHCP support on the WAP4410N or at least IPv6 AutoConfig.Currently, you have to put in a static IPv6 IP for the WAP.I would like to see IPv6 DHCP support as well as IPv6 AutoConfig.It would be nice to allow wireless clients t...
Hi.I recently purchased a Linksys WAP4410N. While I was surprised how much reach I get out of this thing, I now consider maybe upgrading it with a few better antennas.I basically just need to know if the antenna connectors are RP TNC or some other st...
My company just purchased this router for my home office for the purpose of connecting to multiple office locations.I put this router on my network at about 6pm, several machines connected to it and and were given IPs.About 5 hours later I powered up...
Hi all.Got a bit of an odd problem with the WAP200E. I have a requirement to set it up as a wireless bridge, allowing the unit to communicate with another, very heavily locked down enterprise wireless deployment. In testing with the guys that run the...
We have a WAP4410N wireless ap configured for WPA2-Enterprise. Initially everything works. Issue the user the proper certificate and they sign on correctly but once they disconnect and try to reconnect later it get stuck on "Validating Identity". The...
Hello all,I'm in need of some help, with what I hope is an easy problem. We recently purchased an Aironet 521G Access Point. I cannot connect to this thing to configure it at all. Ive tried the browser, I've tried the Configuration Assistant (ver ...
I have a wap4410n ap, replacement for 1 linksys ap running wep, and one cisco 1131 running wpa2 psk. once a day iam forced to reboot the wap4410n as it fails to forward DHCP request to the dhcp server. as others mention the wep works fine.I havent se...
I have this piece at my home and just realized today that there is a new firmware available on the cisco web page. It has made the device more stable, but the most noticeable improvement is in the UI. Previously it was a linksys for business UI tha...
