Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have this piece at my home and just realized today that there is a new firmware available on the cisco web page. It has made the device more stable, but the most noticeable improvement is in the UI. Previously it was a linksys for business UI tha...
New install with 3 AP541N's in a cluster. Two AP's are connected by an ESW-520-8P PoE switch and one on its own power adapter and a 3COM switch. I have set up a single SSID with WPA-AES encryption. I am connecting with HP 2740P tablets with Intel wi...
Hi; we are trying to monitor the signal strength of our 541 N's and we are not sure which MIB's to use. Can someone help out with this?Also; is there a list someone which explains whic MIBS do what with the 541N's?Thx;Dan.
I have been experiencing an extremely odd issue with a couple of my AP541Ns, I configure the APs to use 5Ghz Wireless-N and then set the channel to 100 and leave it, I then come back and access the APs an hour or so later and the APs are now using a ...
HI, this is my first post. I have reading that WAP4410N it's not very popular, we bought 4 units to usead in our office. In our building we have really bad Tmobile Coverage so we decide to take advantage of the UMA Service. Routing Calls trough Inter...
I get a 404 and a pop-up "not authorizationed" (exact spelling) when I try to open the web-based utility from a wired connection. Either through the router using DHCP or with the client configured to the same subnet. No access. None. 30-30-30 rese...
I have a WRVS4400N router setup at home with firmware V2.0.0.8 and ran into issues with SFTP.Standard FTP traffic works just fine, but found any SFTP connection would fail trying to connect.What I found was that IPS enabled for FTP, would cause the S...
After using my WVC200 wirelessly (and thru DDNS service) for about a year without any problems I just moved and got a new router (Actiontec MI424WR Rev. F) from my previous (and current) service provider (Verizon FiOS). Unfortunately, after hours of ...
Hi,I have a Linksys WRV200 WiFi router and read the documentation about it's VPN capabilities.Now I was wondering whether it could be possible to use it as my personal VPN while traveling abroad, instead of subscribing to 3rd-party personal VPN se...
Hi,I am trying to configure an AP541N with WPA Enterprise. My RADIUS server is an MS ISA 2003 and is already working fine with other devices (I have a ASA5510 also configured to use RADIUS authentication with this server). When I try to connect, I am...
After flashing the latest version of the firmware for the WRV200 (1.0.39) all of the pages on the web based admin tool are not working, and some are missing alltogether.I need to be able to re-flash the firmware to an earlier version (or attempt to r...
We are working on a lead where the end customer requires coverage in a radius of 50m in a few deposits with open shelves since their business is very specific. It is a pharmaceutical laboratory. and I consulted how we can document that this equi...
I need to update from older Cisco 350 Aironet 802.11a/b Wireless CardBus Adapters to Cisco cb21ag Aironet 802.11a/b/g Wireless CardBus Adapters in rugged tablet pc's. I need these without the antenna cap present to utilize the tablets antenna sytem. ...
HAI ALL;I HAVE BEEN REQUESTED TO MAKE A PALACE UNDER WIRELESS NETWORK COVERAGE. THIS PALACE COMES AROUND 3000 SQ.METERS. ONE HALL OF THE PALACE IS HAVING BROADBAND CONNECTIVITY ON WHICH WE CAN CONNECT A WIRELESS ROUTER. THE PRINCE WILL NOT ALLOW TO U...
