Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have a WRVS4400N router setup at home with firmware V2.0.0.8 and ran into issues with SFTP.Standard FTP traffic works just fine, but found any SFTP connection would fail trying to connect.What I found was that IPS enabled for FTP, would cause the S...
After using my WVC200 wirelessly (and thru DDNS service) for about a year without any problems I just moved and got a new router (Actiontec MI424WR Rev. F) from my previous (and current) service provider (Verizon FiOS). Unfortunately, after hours of ...
Hi,I have a Linksys WRV200 WiFi router and read the documentation about it's VPN capabilities.Now I was wondering whether it could be possible to use it as my personal VPN while traveling abroad, instead of subscribing to 3rd-party personal VPN se...
Hi,I am trying to configure an AP541N with WPA Enterprise. My RADIUS server is an MS ISA 2003 and is already working fine with other devices (I have a ASA5510 also configured to use RADIUS authentication with this server). When I try to connect, I am...
After flashing the latest version of the firmware for the WRV200 (1.0.39) all of the pages on the web based admin tool are not working, and some are missing alltogether.I need to be able to re-flash the firmware to an earlier version (or attempt to r...
We are working on a lead where the end customer requires coverage in a radius of 50m in a few deposits with open shelves since their business is very specific. It is a pharmaceutical laboratory. and I consulted how we can document that this equi...
I need to update from older Cisco 350 Aironet 802.11a/b Wireless CardBus Adapters to Cisco cb21ag Aironet 802.11a/b/g Wireless CardBus Adapters in rugged tablet pc's. I need these without the antenna cap present to utilize the tablets antenna sytem. ...
HAI ALL;I HAVE BEEN REQUESTED TO MAKE A PALACE UNDER WIRELESS NETWORK COVERAGE. THIS PALACE COMES AROUND 3000 SQ.METERS. ONE HALL OF THE PALACE IS HAVING BROADBAND CONNECTIVITY ON WHICH WE CAN CONNECT A WIRELESS ROUTER. THE PRINCE WILL NOT ALLOW TO U...
First here is our network breakdown8 Windows 2008 Servers - uneffected5 Windows 2003 Servers - effected with dupe IP'sWe have AP - A, B and C all configured static and outside of our DHCP scopeA - 104.240B - 104.241C - 104.242WAP A is setup to allow ...
I have an Imerge SoundServer which streams music via my home network to various zones, including our Conservatory or Sun Room. My wireless network has evolved over the years. The link from the main part of the property to the Sun Room was originally ...
I have a new Aironet 1140N Access point , the model is number AIR-AP1142N-A-K9, my main problem in that i have Nokia E71 smartphones on the network, but they cannot connect to the Network, the Access Point SSID is not showing on the List of Available...
What makes my issue seemingly different from others is that the wireless radios completely shutdown after 25 hours. The V1 hardware was replaced by the V2 and still the same issue. I have swapped power supplies, moved locations to check for heat an...
Hi Team, Yesterday I brought one WAP4410N Wireless-N Access Point and successfully configured with out fail as suggested on getting started and I am able to access internet but unfortunately I am unable to access our local servers and services which...
Hi All,I would like to ask for assistance on how to configure one unit WAP4410N access point to work as repeater to one unit WRT120N wireless router.As a background, I had one WRT120N already in my house before I bought one WAP4410N as advised by a L...
hello people WRVS4400N a need: - For the wireless network can access the Internet and printers ( without access network folders) and do? - A network computer can only access the internet and printers (no access network folders) and do? Thanks Miéc...
