Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
The AIR-SAP-1602I-E-K9 is supposed to be replaced by AIR-AP1852I-E-K9C.
However, this one does'nt play the role of WorkGroup Bridge ...
So I'm looking for a brand new Cisco standalone access point that I can configure as workgroup bridge (or ...
Does the AIR-CAP2602I-K-K9 require a controller to setup on network? I intended on purchasing the AIR-CAP2602I-A-K9 which I have installed in the past without requiring a controller, but the seller sent me the AIR-CAP2602I-K-K9 instead and I need to ...
Hello
I have a router/WAP of my cable company and want to extend the range with a Cisco WAP371. Can you tell me how i can use it as an universal repeater? WDS is not working because router does not support it.
I tried to do it with a WorkGroup Bridg...
Respected Sir/ Madam,
I want to start my small business as an internet services provider. I want to distribute the internet services in my area. I have a broadband connection having 200 Mbps speed with unlimit...
Hello everyone.
I have several WAP321 access points deployed in the network as standalone units and they're working well. Now I'm trying to set up centralized RADIUS server authentication (WPA2-Enterprise) for wireless users using FreeRADIUS.
WAP321 ...
I have 6 WAP-371's running in a cluster. Now I would like to add one more AP without wire as wiring is a little difficult on this one floor. Is that possible? I have unsuccessfully tried WDS bridging.
Thanks!
/Kasper
hi
i have a problem with the cisco wap561
it gives a verry weak wifi signal at 2.4 and 5 gig network ( apple time capsul is twice as powerfull)
power is set to full at both networks and after about 10m the signal is useless cheked it at 3 clients.
p...
I'm trying to write a script to hit my 371s via SNMP and pull client associations (specifically their MAC addresses).
I've tried most of the OIDs I've found mentioned in similar threads / google to no avail.
Does anyone know the magic (if t...
I've been "tinkering" with a setup in my little lab here and have a cisco rv130w and 3 wap121's
i'm trying to understand WDS bridging vs WDS repeater (and Workgroup Bridging)
and when i would use on versus another?
i think i can set them up properly...
I am trying to add 2 x WAP561 AP's to a single point set up cluster that I already have running on 2 x WAP561's. The problem is that whilst the new WAP's accept the cluster name none of the clusters configurations details are updated, such as SSID a...
Hi Cisco,
Firstly, release notes for the new 1.0.1.9 are quite brief and I have already found 2 new features that have made it into the release that are undocumented (sneaky!)
Secondly, I think Spectrum Analysis is now broken and I get a screen stati...
I have been using the WAP371 for 2 and a half years in a variety of locations. I have noticed at one location they were rebooting the 2 APs after a while because they felt it was the cause of their wireless problems. I blamed their clients and to...
