Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi,i have WAP121 AP, I'm facing some range problem, not covering as much distance.How to check AP coverage distance??Are there any tools to get actual distance covering (in meter) each AP because my customer wants detail test report?What is the norma...
I have a wireless network which I don't have administration access to the AP. However I would like to extend the range of the network.Have I misunderstood something or isn't this what the 'Wireless client/repeater'-mode is for?Because I can't seem to...
Working in school environment I have both WAP321 and WAP561 units installed and have set up separate cluster for each model, however how can I be assured that they will not overlap channels. Have seen problems with the WAP561 units, which are in a cl...
Hi,I am struggling to set up 802.1q VLANs on this device being routed from a (TP Link Smart 802.1q VLAN enabled switch).It has all worked as expected on a previous access point so this is making me believe that the switch is configured correctly.The ...
I am getting the following message, not sure where this destination is nor where to configure it. any help will be appreciated, thank you.Log Message from AP xxx.xxx.xxx.xxx TIME Priority Process Id Message============...
Hello everyone, I have few WAP321 with a radius server listening on 2 different IPs (one for each SSID). I configured the global radius server with theses two IPs. Then I created 2 wireless networks with WPA enterprise, global radius settings. ...
I'm trying to access a Cisco WAP551 but give an error: "The server at 192.168.1.245 is taking too long to respond." We have reset it but the problem persist. We have 2 Cisco WAP551 and both have the same problem.We can't access to the configuration. ...
Hello,We have 3 WAP321 setup in a cluster mode.They will work for about an 30 minutes to an hour then nothing. The lights are on, its still brodcasting the SSID, but no clients are able to connect and we are unable to get to the management interface....
I have 5760 WLC with 3702 wireless infrastructure. Can i connect a WAP4410N AP as WGB to be attached to my current wifi network so i can provide connectivity to some wired devices? Any tips on doing so? And any limitation can be imposed for using thi...
Bonjour, Je cherche désespérément l'oid se référent au nombre de stations connectés à la borne wifi. Je ne trouve rien nulle part. Qq'un aurait une idée ? Merci d'avance.
Hello everyone,I'm trying to set up a WAP 371 to authenticate wireless users using the captive portal and a RADIUS Server for authentication. Whenever trying to authenticate however, the captive portal rejects the credentials. From the logs of the RA...
Hello guys,please what are the requirements for custom SSL certificates on WAP4410N? I have created SSL certificate (in PEM format) using my own CA with EJBCA soultion, but after pressing "Install certificate" button on "SSL Certificate Management" s...
I'm not quite familiar with those advanced features if it does exist as the fact that i've been primarily using cheap and unknown AP products for years :D I'm planning on upgrading my APs for personal reasons. Could anyone tell me does it have a feat...
HI Thanks in advance we have small business company , we are using cisco WAP 321 we are getting issue on my AP ERROR: getOptRdata - unknown opt 65002 , slow internet speed , when we ping we are getting request time out , Kindly suggest solution ...
have a new wap4410N access point. i log into the the default IP address 192.168.1.245 only showing ( it work! ). so how can i enter the admin page please help me i need to change wi fi password and name and i using os x
