Security
Explore the security forums and share your expertise about firewalls, email and web security, Identity Service Engine, VPN, AnyConnect, Duo, Umbrella, Secure Access and more.
Browse the Community
Network Access Control
Network Security
Engage with peers and experts on network security topics such as Secure Firewall Threat Defense, Ada...
Duo Security
Get started with or get better at administering and using Duo by interacting with peers and experts!
OpenDNS
Ask questions not covered by support articles and documentation.
Activity in Security
trouble with open dns dashboard
 After deleting a network in my OpenDNS account, logging in redirects to opendns.com and shows a 404 'page can't be found' error. how can i reset my dashboard default route or recreate the network slot ?
cti-vgd by • Community Member
  • 185 Views
  • 5 replies
AI Model Context Protocol (MCP) and Security
The Model Context Protocol (MCP) is an open standard that provides a universal way to connect AI models and agentic applications to various data sources and tools. It's how AI applications and applications can supply context (documents, database reco...
OmarSantos_0-1742780256382.png OmarSantos_3-1742781114086.png OmarSantos_1-1742780256397.png mcp-security-omar-santos.png
Omar Santos by • Cisco Employee
  • 84779 Views
  • 4 replies
  • 24 Helpful votes
CIVS-IPC-8620 firmware
Hello, I’m looking for firmware version 1.0.9-8 for the CIVS-IPC-8620 camera. Could anyone help me with this?
s-humbatov by • Community Member
  • 133 Views
  • 1 replies
FMC couldn't deploy to FTD after unsuccesfull VDB update
After unsuccesfull VDB update from v.432 to v.433 on FMC v. 6.6.4-59 deployment process to FTDs isn't work and we get the error "Deployment failed due to failure in generating configuration for device. If problem persist after retrying, contact Cisco...
d.ostapenko by • Frequent Visitor
  • 196 Views
  • 3 replies
Cisco IOS: Stateful inter-VLAN access with NAT and ACLs
Hello Cisco Community,I am looking for guidance on implementing stateful communication between two internal networks on a Cisco IOS router.The requirement is to allow connections initiated from one network to another, including their return traffic, ...
Tecnico F by • Visitor
  • 816 Views
  • 8 replies
Slow speed in IPSEC VPN between Cisco FTD 2130 and AWS VGW
We configured route based IPSEC VPN between Cisco FTD 2130 (pair in HA, v.7.2.8, managed by FMC) and AWS VGW with BGP - 2 tunnels: one of them is main and other is backup (main is choised by local-preference and as-path prepend in BGP). Internet chan...
mofnoc by • Level 1
  • 258 Views
  • 6 replies
Managing SGTs in FTD in an scalable way
Hi,Our environment has dozens of SGTs. Everytime we create a new SGT we need to add it on every single firewall rule it belongs to, as far as I know, it is not possible to create groups of SGTs and add them into FW rules so any new SGT can be just ad...
Resolved! Cisco ISE default behaviour for reset account lockout counter
Hi experts, For compliance purposes, I was asked to define the default behavior for reset account lockout counter after for Cisco ISE.For the context, my current setting on Cisco ISE is to lock the account after 5 failed attempts (which another admin...
1Kim by • Community Member
  • 441 Views
  • 8 replies
Resolved! ASA VPN Interface
HiWe have an ASA firewall in a HA setup and currently are moving over to a new internet circuit that is provided by the Data Centre. Previously the Public range extended out to the next hop address so the VPNs terminated on the outside interface.Howe...
Day 2 Of Requesting Exact Searches in DuoAdmin Portal
Please add the ability to search for an exact username in Duo Admin Portal. Since i search for many users by exact username only, i often have to spend time going through the 'Users' tab to find a specific user.Community Bug or Issue, Duo Security Di...
cjc7 by • Community Member
  • 258 Views
  • 6 replies
FTD - wrong time in ACL Hit Count
When I check hit counts from an ACL in our FTD-unit (via the FMC) the time stamps have incorrect values. Study the attached screen shot. Hit counts where fetched at 13:22:27 but the "last hit time" is 13:44:49 (i.e. approx 22 minutes into the future)...
