Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
We have a requirement to make some alert text messages display on our Cisco IP phones.  What are the options for sending a message to a Cisco Phone?  I read about the JTAPI sendData command which sounds like what I need.  However there are some inter...
Mike34 by • Community Member
  • 2489 Views
  • 2 replies
Hi All, I can see that the official stance on JVM versions is 1.7.0.79 (under Oracle specific as well).... https://developer.cisco.com/site/jtapi/documents/cisco-unified-jtapi-supported-jvm-versions/   Is there any reason why such an older JVM has to...
tleask by • Cisco Employee
  • 1205 Views
  • 1 replies
Hello,Refer to the link below, Cisco JTAPI (for CUCM12.5) is considered to be compatible with RHEL7.Is it compatible with RHEL8?If that is not currently supported, are there any plans to support it? https://developer.cisco.com/site/jtapi/documents/ci...
HD_RR401 by • Level 2
  • 1266 Views
  • 2 replies
Hello, I'm trying to access the CUCM using zeep python library and I'm having an issue with the client method. I'm loading ACLAPI.wsdl as a local file, so I defined: WSDL_URL = 'file://C:\\Users\\dgonzalez\\Trans\\Devnet\\Schema 10.5\\AXLAPI.wsdl' an...
i am running some Tapi tests regarding user login or logout using jabber.Configuration:cisco tsp 12.5.1lineNegotiateAPIVersion: : cisco tsp returns tapi version 0x00020001lineNegotiateExtVersion: cisco tsp returns 0x0000000F.Registry: EMOptions is 1....
christian.la by • Community Member
  • 1098 Views
  • 1 replies
I am working on Cisco UCCX and I am using Cisco UCM integration. When I am calling from external number ('customer') to one of Cisco extensions ('agent') I am clicking 'Decline' on the agent's Cisco Jabber. Then I am redirected to the agent's voicema...
Zygmuntix by • Frequent Visitor
  • 1552 Views
  • 1 replies
Hi, I am building an application that requires digit key pressed events (such as 1, 2, # etc) to be captured from SIP phones. I have followed the Cisco JTAPI 11.5 guide and enabled the CiscoTermEvFilter.setButtonPressedEnabled(true) before adding a T...
anoopr by • Visitor
  • 6453 Views
  • 4 replies
