Does Cisco Unified Communications Manager Cloud support device/call control via TAPI?
Hello!We widely use python script for automation CUCM administration taskWe used SUDS - SOAP python client library for make requestFor example it works fine for SQL queryquery ='select count(*) from enduser'resp = client.service.executeSQLQuery(que...
Hi, We use sandbox (CUCM12.5) to monitor call events between extension terminals (using JTAPI).When we executed the hold on one extension, CallCtlTermConnHeldEv was generated, and after waiting for about 20 seconds, when the hold was released, it ret...
Hello all- I have a situation trying to record a call via BIB media forking to a third-party recording application. The environment is using secure audio, the phones register correctly and the call audio is secured as expected. Certificates have be...
Hi, One of our customer has Cisco Jabber and WebEx Teams Client deployment. Initially we have deployed our MARS Agent Greeting solution for their Cisco Jabber Client. Now customer also wants same solution for their Cisco WebEx Teams Client which is r...
Hello, we are developing a solution to add devices in cucm and manage them. With CUCM 12.5SU3 we face an issue when adding a CSF Device, all other Devices are working. In previous releases also CSF Device was fine. Does anybody had this issue and kno...
The "getting started" guide isn't really that.. it's, "install this", read "that". But "that" are basically documents that explain how CUCM and devices communicate, what's in which SIP header. Plus there's one guide about manipulating SIP messages. I...
Hi,Me and a collegue are programming an internal website to give Management/Techsupport the ability to view who is registered with each of their Devices (CSF/SEP/TCT/BOT...) and see, for each device, if they are logged into their corresponding linegr...
I am using JTAPI to make and receive calls. Most are working but a bunch of devices keep failing with this error. What could cause it?
I'm trying to build a SPANless call recorder. It's registered as a SIP trunk and hooked up as a call recorder. I have a phone setup for automatic recording and when it's on a call I get 2 INVITEs and then 2 RTP streams. It does work but only sometime...
I notice in the JTAPI Developers Guide that getAddress() is the only method for CiscoAddrRemovedEv (other than inherited methods). However, when I check the definition of CiscoAddrRemovedEv in NetBeans it shows both getAddress() and getTerminal(): pa...
Hi,one customer wants to develop one C2C application where, instead of placing the call between the dialed number and the Cisco IP Phone, they want to connect the dialed number with the end user GSM number. This is what DVO offers, and I see DVO as a...
Hi team, Wondering if one of you would share some sample code that does the following : Query MS AD based on a calling number, get some field like Calling name and Calling number and then replace the current CUCM fields with what we got from AD....
Hello All - I am trying to build a JTAPI application and need some inputs for the design . My application is JTAPI softphone which sits inside a CRM, used to control users desk phone/Jabber. I would have a web server and application server hosting JT...
Hi Everyone,I have implemented the whisper coaching by updating the silent monitoring to WHISPER_MONITOR, however the customer on his extension can still hear the supervisor's voice. Is there anything missing out in my program/event that i need to im...
| Subject | Author | Posted |
| 07-22-2026 03:11 PM | ||
| 12-14-2025 04:02 AM | ||
| 10-17-2025 12:27 AM | ||
| 07-22-2025 11:48 PM | ||
| 07-10-2025 11:24 PM |
