Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hi I am looking for API where i can use ti develop a gadget to provide call control features such as Make call / hold / Retrieve / transfer / Conference.  This is not via agent login. Non-ACD calls for non voice agent. Please do share the me the deta...
venchalam78 by • Community Member
  • 1196 Views
  • 2 replies
Hey community, I am working on a JTAPI project. I am stuck on something and came here to ask for a small help.if (event instanceof CiscoCallEv) { CiscoCallEv ciscoEvent = (CiscoCallEv) event;         ciscoEvent.getCall().toString() // this returns so...
melroy by • Visitor
  • 1257 Views
  • 1 replies
We are working to connect Genesys PureConenct and Genesys PureEngage together, passing through Cisco CUCM.  We have a SIP trunk from CUCM to Connect and a SIP trunk from CUCM to Engage.  The original proof of concept had an INVITE sent from CONNECT t...
djohnson by • Level 2
  • 4357 Views
  • 3 replies
Hello,  I have a CTI appllication that works fine. Tried to secure the CTI connection following this very good guide. https://community.cisco.com/t5/collaboration-knowledge-base/configuring-and-troubleshooting-secure-jtapi-cti/ta-p/3125041 I have a c...
RITT by • Level 3
  • 1413 Views
  • 1 replies
Hello, at the moment we implement JTAPI to our solution. Because i dont want to monitor all Phones in the CUCM cluster, i was thinking if it is possible to monitor also SIP Trunks to see all calls which are running on the SIP Trunk. Is there any API ...
How to make DTMF and TTS work in cisco jtapi system. What are its settings so that my call goes from one phone to another phone. In what way can these two be used in my Java code?
santanudee by • Frequent Visitor
  • 1386 Views
  • 3 replies
You 15-12-2023 00:35 •Hi, I am new to Cisco CUCM. I am trying to run the application https://github.com/CiscoDevNet/jtapi-samples/tree/master to make a call in JTAPI.I create one application user in cisco Unified CM Administration but still I am not ...
souradeep by • Frequent Visitor
  • 998 Views
  • 1 replies
Hello - Looking for some help with JTAPI implementation. Plan is to build a web softphone for 3rd party call control where the purpose is only to control the device through the UI. Reading the developer guide looks like I need to get provider (I read...
PVYAPA by • Level 2
  • 5946 Views
  • 7 replies
