Contact Center
Is there any way or has anyone developed something which will give an on screen indication to Agents that they are in RONA without having the WebEx CC screen or desktop app open?  We have created our own Secondary Ringer to help staff hear a call com...
Dear All,We installed CUIC 12.6.2 ES08. After installation, custom and stock reports using anonymous PL/SQL blocks with multiple parameters no longer functioned correctly, and report filters were unavailable.We then installed the Rollback COP (ciscoc...
We have UCCE with CVP 12.6.Is there an option to automate the steps outlined below? Has anyone attempted to accomplish this? This is for a Disaster Recovery exercise.1. Stop Call server gracefully2. Check active calls remaining in CVP.3. Once all the...
hello, in my lab i have integrate uccx with ccp without any problems and everything is ok.But when i try to send an email from outside the mail still on ccp and not delivered with cisco fineese and in my fineese it showing "There are no active chats ...
HelloI am writing a script where a call must be connect to a specific agent. So customer calls a specific number and from the number I have to find the agent name. This is possible with the GetUser step from the script, I have the called number, and ...
Hello,I have a Cisco 12.5(2) PCCE setup. I finished configuring all the components, and now I am trying to add them to the inventory. I need to first set the deployment type to PCCE 2K mode. After this i am asked to enter the credentials. I already a...
inasr by • Level 1
  • 176 Views
  • 0 replies
Does Webex Contact Center integrate SDKs of Jabra, Plantronics etc into their Browser, to allow Headsets to accept CC calls using the Headset buttons? I could not find anything on it, so i would assume not?
pescla by • Spotlight
  • 334 Views
  • 1 replies
