Network Security
Engage with peers and experts on network security topics such as FTD, FMC, FDM, CDO and ASA.
“Join
Labels
Hello, I’m not at all familiar with any of the intricacies in any way and really am just requesting a simple version answer for this please. I just want to know which asa image file I need to use and what adsm image to use in order for the firepower ...
My understanding is that URL feeds in FirePower SI are updated dynamically and take effect w/o having to do a policy deploy to the FTD. Does the same apply to custom URL feeds used in an ACP rule? My idea would be to create a custom URL feed on a loc...
tato386 by Level 6
  • 237 Views
  • 8 replies
Dear Community,I have a pair of FPR 3105 devices which have been reimages to ASA & running as ASAs with traditional ACL services.I don't have applied the Basic STD licensee; it has expired now post 60days of trail period. I am getting the throughput ...
Hi team, Need help in understanding an issue faced when creating a tunnel between Asa and Sonicwall (Issue got resolved) still need help to understand. SonicWall: Phase 1Ikev2Encryption aesAuthentication sha265Dh 14Lifetime 86400 Asa: phase 1Ikev2 En...
SajeshB by Level 1
  • 6605 Views
  • 6 replies
@Marvin Rhoads kindl please suggest if my approach is right as the cisco documention is overwhelming. what I read from your post replies and other this is the right process from FMC1000 migration to FMCv • 1 Deploy new FMCv in virtual environment • 2...
This might be a dumb question but how would you set up the ASA firewall 1000 without internet connection? I have a switch that connects to it. I think I can console into it with putty but isnt there a gui ?
Hi All,   I have a need to deploy an HA pair of ASAv in Azure.  I've read the Deploy ASAv on Azure Cloud document and I understand that the ASAv is required to have interfaces in four subnets, not including the Azure GatewaySubnet.   My Azure Virtual...
Tim Glen by Cisco Employee
  • 2108 Views
  • 6 replies
Hello, I have a firewall configured active/standy lan failover. Over the weekend there was something that happened and now the standby is active. Below i posted the failover state, for security purposes i just left out the actual ips on some. I know ...
petoria by Level 1
  • 3515 Views
  • 2 replies
