Hi,In general, how to find echo source and fix echo problem between IP phones in IP network, not pstn. Any suggestion would be apreciated. Thanks!Steve
I have been trying to get my ccme to append 1772(1+area code)on my 7 digit calls but have been unable to get it to work. I ahve included my config, can anyone give me an example of how to make that work? voice translation-rule 1 rule 1 /9911/ /911/...
Hi all,I have the following issue and I hope that someone will help me to solve this problem:When a customer calls a number, it is forwarded to a Hunt Group with 3 members. Hunt Group has been configured with Longest Idle and Timer for 25 seconds. Wh...
Version 7.0.1Do I need to do anything besides having phones in both clusters encrypted?
Hello all,I have a client with a CME 3.4 system in at a concrete plant. What they want to accomplish is that when a phone internally rings, they can have an outside loudspeaker which will alert them by ring or other audible alert to let them know th...
Hi All,I have got a bunch of MCS7835-H2 servers running Linux (CUCM 6.1, Unity Connection 2.1, CUPS 6.0 and MeetingPlace Express 2.0). During the installation process all these servers have used PS2 keyboard and mouse. Now the customer wants to migra...
We currently have about 20 analog fax lines. I'm trying to see who has had great success with the VG224 using T.38. Our gateways are currently MGCP that support T.38 and I understand the VG224 does the same. The only results that I find when Googl...
Hi All, We have a number of users at home using IP Communicator vpned into our network (Juniper client software). We continue to struggle with QOS issues (JITTER). All users are using G729.One of my users upgraded his bandwidth to 5mb down and 1 mb ...
Can I stop this servic if I use external DHCP, not DHCP CUCM?
I don't get an error. it just basically times out. Should I reload the cue againits version 3.0
We have (2) CCM 4.2 servers(primary/backup) and (2)Unity 4.2(1) servers (primary/backup) handling 50+ branches in 3 different timezones.We use TOD routing with CTI RPs to manage the calls for OPEN and CLOSED hours. Depending on the TOD, the call wil...
Hi,I would like to know more on Cisco Unified Presence 7.0 Licensing, with CUP6.0 which was part of a CUCM6.0 Bundle, we had to add 1 DLU per Presence Aware User, however the Data Sheet of CUP7.0 doesn't state in detail about the Licensing, as part o...
Has anyone experience this before a PC not getting an IP Address fromthe DHCP server when you reboot the PC. Only way to get an IP is todisconnect the network cable from the PC port on the IP Phone andre-connect then it gets an IP Address.CallManager...
I have 3 sites, HQ and 2 remote sites. CMs (v6) are deployed at HQ and SRST is deployed at the remote sites.All PSTN links come into the HQ and calls are sent over the WAN. if/when the WAN goes down and SRST kicks in and remote sites use local pstn l...
I have 2 CMEs located locally. Want to configure Failover between them. Will simple HSRP configuration be enough or I need to configure telephony services also to enable failover?Thnx.Ashish
Subject | Author | Posted |
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM | ||
05-16-2025 12:03 AM |
User | Count |
6 | |
4 | |
3 | |
2 | |
1 |
