IP Telephony and Phones
Labels
Good Afternoon all! :)I was wondering if anyone could lend me some assistance. I have installed my FXO module within my 2611 router and would now like to upgrade the ios so that it can support the voice but so far all the images seem to be way too hu...
Guysive just connected some VT Cams and my test users cannot dial out through their PRI.If i disable Video everything is fine. i understand that the command bearer-cap Speech should resolve the issue but im not seeing this command under the voice-por...
a.gooding by Level 5
  • 2114 Views
  • 1 replies
Hi,I have a couple of 7971's that will not boot up, can't even perform a factory reset on the phones. I've tried booting up with a power block as well but all I see is the speaker light on and that's it!Is the phone now dead or is there anyway to re...
jacka by Level 1
  • 427 Views
  • 2 replies
Hi All,I have two routers connected with PPP (256 kbps) leased line and going to implement QoS for voice traffic.my config is belwo which i got from cisco.class-map voipmatch ip precedence 5!policy-map llqclass voippriority 128class class-defaultfair...
Does VG224 used for wallphone and Fax need to config dsp profile for ccm? I have already 2 ISR routes with enough DSP resource configured with CCM. Shall I configre DSP again in VG224? I think I have enough DSP for xconding, termination and conferenc...
CCM use mgcp with gateway, I hope to add a PSTN access code(90) in the front of the calling number when inbound call, this can make agent dial back call easily. I tried to use translation rule in VG , and put this rule in each E1 voice port, whereas,...
Hi all. Im looking at implementing a call pickup group. Im wondering what is the usual implementation here. It seems like when you dial the pickup number, I should think that you should be able to dial the extension of the phone that is ringing. ...
jjoseph01 by Level 3
  • 887 Views
  • 5 replies
