Network Management
“Webinar
Labels
I have been stuck at this assignment for a week now. No matter what I try even redoing the whole thing serveral time, I can't seem to figure out why the DHCP server is not working for the PCs. I would really truly appreciate if you can help me find o...
Hi everyone,To all engineers who love cisco CLI, what is the possible solution to this below errorKey exchange failed.No compatible MAC. The server supports these MACs: hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sh...
Good day,I require some Assistance.I have Configured Radius Authentication on all of our Cisco Switches, but I have Randomized Issues that I am not sure how to fix. The Authentication works 100% on our Domain computers.With some computers we have a I...
Good morning, requiring some assistance for bulk loading conference spaces on my CMS 1000 server.  I am currently running the VM application Meeting server v3.0 on a CISCO UCS-c220-m5 server.  I can build individual spaces and passcodes, and while th...
Resolved! DHCP not working
I have an ISR4321 router and a 2960x switch. I setup a super basic config, with DHCP. My laptop never gets an IP address. Static works fine to get to the internet.ISR4321/K9 running 16.09.04!hostname Test-Routerip name-server 8.8.8.8 1.1.1.1ip dhcp e...
Amills by Level 1
  • 135 Views
  • 4 replies
Hi,With stateful ASA FW pairs you configure interfaces with primary and standby IPs.Must standby IPs necessarily be within the same LAN as primaries?If so, must they be within the same VLAN? Or can routing be used to interconnect them instead?For MGT...
mickpro77 by Level 1
  • 409 Views
  • 9 replies
Is there any way by which we can find the number of routes and number of received routes using snmpget.OID - 1.3.6.1.4.1.9.9.187.1.2.4.1.1 gives us information about the routes accepted after appling filters. But is there and OID for received-routes ...
We were given the following details:The L2 PVLAN has been created:PVLAN- 123Name: pvlan-XXX-L2Primary IP: x.x.x.131/27Subnet: 255.255.255.224Gateway: x.x.x.129 However, when we plug in the router's WAN port to the PVLAN port in the office (and config...
2sg3arcw7 by Level 1
  • 106 Views
  • 1 replies
