Network Management
“Webinar
Labels
I have an ISR4321 router and a 2960x switch. I setup a super basic config, with DHCP. My laptop never gets an IP address. Static works fine to get to the internet.ISR4321/K9 running 16.09.04!hostname Test-Routerip name-server 8.8.8.8 1.1.1.1ip dhcp e...
Amills by Level 1
  • 75 Views
  • 1 replies
Hi,With stateful ASA FW pairs you configure interfaces with primary and standby IPs.Must standby IPs necessarily be within the same LAN as primaries?If so, must they be within the same VLAN? Or can routing be used to interconnect them instead?For MGT...
mickpro77 by Level 1
  • 396 Views
  • 9 replies
Is there any way by which we can find the number of routes and number of received routes using snmpget.OID - 1.3.6.1.4.1.9.9.187.1.2.4.1.1 gives us information about the routes accepted after appling filters. But is there and OID for received-routes ...
We were given the following details:The L2 PVLAN has been created:PVLAN- 123Name: pvlan-XXX-L2Primary IP: x.x.x.131/27Subnet: 255.255.255.224Gateway: x.x.x.129 However, when we plug in the router's WAN port to the PVLAN port in the office (and config...
2sg3arcw7 by Level 1
  • 101 Views
  • 1 replies
Hi,I've recently been tasked with allowing SNMP access to a device for identification only.  No other SNMP access.  I believe what I want is the 1.3.6.1.2.1.1 area, which is the system OID.From what I can tell I should be using views to meet this req...
