IP Telephony and Phones
Navigation banner_4
Labels
Hello Team,I need help with call blocking configuration in Cisco Unified Communications Manager.We have an IP phone extension (example: 1001), and we want to block incoming calls from specific numbers so that calls from those numbers should not ring ...
ag0022005 by Frequent Visitor
  • 412 Views
  • 7 replies
How long does it take for an unregistered IP phone's status to change to 'None'? Based on my research, it should only take 72 hours; however, I noticed that some IP phones still show a status of 'Unregistered' even though they were disconnected 10 da...
Hi, We are planning to buy 500 Name user licenses A-FLEX-NUPL-A. Have couple of queries as below1) Only 500 End users can be created or more in CUCM who can do login/logout (extension mobility)? 2) For 1 End user how many IP Phones can be associated?...
Jagadish2 by Level 3
  • 271 Views
  • 1 replies
Hello, Here is an example scenario: Phone A calls ext 4001. On Phone A's display it is showing "Voicemail" as the called information. Instead we want it to show "Hulapi" which is configured on the line of 4001 I think this is happening because ext 40...
