Routing
“Webinar
Labels
I have a Catalyst 2960-X model switch with the port 3 and 4 led blinking green ( communicating ) and suddenly starts blinking orange for a few moments and then flashes green normally. It's been swinging all day. Thank you
Translator by Community Manager
  • 68 Views
  • 1 replies
in the shown design , why the PC connected to R1 can't ping to the last PC , while R1 can ping to the last PCnote : The PC connected to R1 already configure the default gateway R1
I have a Cisco 2951 router, and I switched the domain name from localdomain to 'mydomain.us'The few local hosts I have, I resolve on the router, while hosts outside my domain I forward.  It looks like this:ip domain name mydomain.usip host seismo.myd...
roncro by Level 3
  • 228 Views
  • 8 replies
ASR 9904 using DC V2 power supply its major alarm persist after turn on power supply , it’s disappear only after remove and re-insert the power module, can anyone know the cause?
Hi, I bought two refurbished 2911 routers for a home lab. When I boot them up, they both have solid green lights under "SYS" and "PS". I have a console to USB cable and use putty to access the routers. I plug the console cable into the router and the...
Hey, We have just received a brand new C8500 / 20X6C. Is there a command to get the current power consumption of each power supply ? "show platform power" command says "Power audit feature is not enabled." How to activate this power audit feature ? B...
dbillon by Level 1
  • 181 Views
  • 6 replies
Hi to all ,i am trying to figure out why i can't have a cellular connection to my ISP , although having already read and tried various commands from different threads and sites.My config is pretty simple :interface FastEthernet0/0ip address 192.168.1...
Ditter by Level 4
  • 94 Views
  • 3 replies
Hello,  I am trying to open a port in my Cisco router using the command, ip nat inside source static tcp 192.168.102.2 25 interface Dialer1 25, but no luck. Could someone please help? The router is a Cisco 886VA Below is my configuration:Current conf...
Hello,i have an ISR 4431 Router with broken flash. The device has been registered with Cisco but i have no additional contract.According to the chat support, there is no way to download again the IOS delivered with the router?Any idea how to do this?...
wh17 by Level 1
  • 141 Views
  • 6 replies
 Hello,On our branch i have  2 path to the internet, 1st via local internet on the site and 2nd via Head Office via WAN.All traffic to other branch, Head Office should pass thru via Head Office via WAN and all internet traffic including to Microsoft ...
hs08 by Spotlight
  • 259 Views
  • 16 replies
Unanswered Topics
