Routing
Labels
A simple topology of three routers R1, R2 and R3 connected in a multiaccess segmetn.R1#sh ip os int f0/0FastEthernet0/0 is up, line protocol is upInternet Address 123.1.1.1/24, Area 0, Attached via Network StatementProcess ID 1, Router ID 1.1.1.1, Ne...
Hello I have  very simple configuration on cisco 892 k9 router to run dhcp configuration, but sadly its not working i did trying restart the service but didn't worked. please check the  configurations.Router#sh runBuilding configuration...Current con...
I setup a site to site VPN with a pair of FTDs using the FMC VPN wizard and static VTI interfaces.  Each FTD has two ISPs so I configured a backup tunnel using the 2nd set of ISPs and VTIs. I also setup BGP using the primary set of ISPs and VTIs. All...
tato386 by Level 6
  • 150 Views
  • 0 replies
Hi team, I have a device: C8200L-1N-4T and NIM-2FXSP. I want to "show voice port" on CLI but it's doesn't work. I haved show the commands "show inventory" and confirmed that the NIM-2FXS module is detected, so why am I unable to run the show voice po...
HatDauNho by Level 1
  • 154 Views
  • 1 replies
  • 1 Helpful votes
Hei all, I was trying to find any information about this upgrade path through release notes, but it is lacking any information about steps in the upgrade. I was also getting through some forum topics already posted and went through few. It would be g...
Tomson by Level 1
  • 2961 Views
  • 5 replies
I don't know how to solve task 6 and 7 simultaneously when we have to use two distribute list on a same interface. One for the access list on R2 and second for the prefix list on R2 towards R1. I need a solution ASAPRouting, EIGRRouting, EIGRPP
