Small Business Support Knowledge Base
Get the support you need with our Small Business Support Knowledge Base, featuring helpful articles and resources.
Knowledge Base Articles
Article ID:5260 Objective The Cisco SG350-28P 28-Port Gigabit Power over Ethernet (PoE)Managed Switch is a standalone switch that provides 24/28 ports of Gigabit Ethernet and 4/28 (2 SFP + 2 Combo) Gigabit Ethernet ports. It comes with a new g...
Objective Call Progress Tones are used to show the status of the phone calls. These are audible tones which define the level, frequency and cadence of the dial and thus give the progress of the call which is made.The majority of the Call Progress To...
Introduction Enabling Auto Answer Page on the Cisco IP Phone allows it to automatically answer any incoming call or page without you having to accept the page. This feature is designed to work using the speakerphone or a headset. To automatically a...
SFP Module Support List for RV160x and RV260x Devices Small form-factor pluggable (SFP) ports are included on the RV160 and 260 routers to allow the use of optical SFP transceiver modules. SFP’s convert the optical signals to electrical signals. SFP...
Jose Correa by Cisco Employee
  • 4449 Views
  • 1 comments
  • 15 Helpful votes
Quality of Service (QoS) is useful in networks where traffic prioritization is desired. With QoS you can separate traffic and give priority to specific types of traffic such as video or audio applications, or any other data traffic, according to your...
almoncad by Level 1
  • 1363 Views
  • 1 comments
  • 10 Helpful votes
Top Contributors
