Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2954 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4547 Views
  • 1 replies
  • 16 Helpful votes
     Team,I have more than 500 SG200,SF200 switches in my network. Now we are running a project to standardised the configuration on every switch. So we nned to collect running config,inventery ets from this switches, which takes lot of time as this ...
I need 2VLAN on 2 SG300-28.1st SG300 - name sw1, 1VLAN - 192.168.0.102st SG300 - name sw2, 1VLAN - 192.168.0.11LAN is 192.168.0.1/24 GW 192.168.0.1 On SW1 i create 2VLAN (10 and 100), port 3,4 in accses mode for 10 and 100 VLAN.after that, i create 2...
I have had a hard time wrapping my head around tag and untag options on VLan ports. I have a Cisco SG300-52 that I have 2 VLan's on: VLan 1 (default, internal LAN) and VLan 10 (will be going to my wireless and is fed from my DMZ port on my firewall)....
jay.enebo by Level 1
  • 3934 Views
  • 3 replies
Hi Guys, I have an sg300 with vlan10 for data and vlan20 fore voice. I have voice vlan enabled, I have ports assigned to vlan10 untagged and vlan20 tagged. The plan is to plug PCs into the port on my phones. The issue is how do I configure the uplink...
I have a SG300-28P that when I plug in a Avaya VOIP phone, changes from tagged to excluded on my VLAN 50 that I have set aside for phones.  The phone that doesn't work until I change it back to tagged.  Then if you reboot the phone, it doesn't change...
HiAt school I want to start using 802.1x authentication with dynamic Vlan assignment by a Windows Server 2012R2 Radius server.When a student logs in, I want it to be placed in the "Students" Vlan, when a Administrative employee logs in, I want it to ...
RMA
I have SMBS contractI have got new switch as a part of replacement policy and working fineHow I should return the faulty switch to cisco ?I have to manage it or cisco will arrange a pickup for me ?what about the cost of sending a switch back ?
I plugged a new Cisco SG300-10P into an access port on our Cisco 6513, which is in vtp mode.  I am thinking I will need to create a trunk port from the Cisco 6513 to the SG300-10P, in order to carry my desktop data vlan 1, and my new shoretel VOIP vl...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
