Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3444 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4990 Views
  • 1 replies
  • 16 Helpful votes
Hello, I'm pretty new to networking and managed to get hold of an SG200 and some other hardware. The rest appears to be working perfectly, however the SG200-18 seems to reboot every 12 seconds. The power light flashes continually (I assume normal f...
Hai team,                 My name is arun . I have one issue. Please help me using your valuable advice. I have one Scenario . We have two cisco switches sg 300 and two firewall Sophos UTM 230. One fire wall is master and other is slave for high ava...
ARUN.A by Level 1
  • 1512 Views
  • 7 replies
Hi All, Have you ever seen below message on SG500 switch before ? Jul 12 04:21:18 atviesw01 1 2016-07-12T02:21:17Z atviesw01 SYSLOG - OSFATAL - %SYSLOG-F-OSFATAL: FATAL ERROR: GOAH: ABORT DATA exception ***** FATAL ERROR ***** SW Version : 1.4.5.02...
pokemon by Level 1
  • 1348 Views
  • 3 replies
I have a SG300 that is running 1.4.5.02 and need some help with ACL's. My intention is to lock things down where services aren't accessible from the outside. Here is the configuration at the moment. We've tested and SSH and HTTPS are accessible from ...
phusion2k by Level 1
  • 740 Views
  • 0 replies
Hi, I am pretty new to networking with Cisco equipment, but we have had an RV325 now for a while that I've gotten used to and have a couple VLANs set up on. We had been running with just the RV325 and a WAP371 supporting about 35 associated devices a...
joey.khan by Level 1
  • 657 Views
  • 2 replies
I have 9 PCs at a SG300-10 switch running. Everything works fine, however, in the RAM memory log I can see permanently DOWNs and UPs. What is the reason for that behaviour? Another swtich SG300-20 does not show this behaviour.214748332717/12/12 10:10...
Hello, I was hoping someone could help with a potentially easy (stupid) question.  I have powered up the switch and the system light is blinking green.  Now I want to and want to add it to an existing network.  According to the quick start guide, whe...
tladd0001 by Level 1
  • 592 Views
  • 2 replies
We have 2(two) SG300-28 switches. We have several VLANS that need to be truked between switch A and switch B 1. We are able to create 1 TRUNK port  that includs vlan 2,3,4 and it works fine between switch A and B.  We are now trying to create a 2nd T...
soupensu by Level 1
  • 378 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
