Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2929 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4512 Views
  • 1 replies
  • 16 Helpful votes
Resolved! SG300 LACP failing
Hello, i Work i a school responsible for al what is computer related (network, servers, workstations, ....) i have 31 SG300 series switches (L2) and 1 (2 in stack) Catalyst 2960X L3 switch acting as a Core switch. one link of the trunk goes to one in...
I have a number of SF300 switches installed in a building that have been set with their default settings. There is a single switch per floor, with each floor having a number of tenant areas, and one switch for the landlords area, I would like to set...
I messed up my Cisco 3560 Switch :( I downloaded the newest IOS for the switch and removed the old flash files to gain more room.  I started installing the IOS like normal, then stepped away and when I came back I thought it had finished and reloaded...
I have a SG300 switch in L3 mode. This is what I have right now: Switch boots into VLAN 1. I wanted to create a second VLAN 2, 10/24 subnet. 84.5.163.129 is the external router switch is connected to. The routing table: S 0.0.0.0/0 [1/1] via 84.5.16...
anilj0001 by Level 1
  • 328 Views
  • 1 replies
Hi,i was checking the datasheet of 500X series and got confused regarding the 10GE uplinks. how many 10GE ports can be used for uplink and which transceiver should be used for 10GE copper uplink? for example, SG500x-24 switch has 24GE ports and 4x10G...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
