Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2643 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4174 Views
  • 1 replies
  • 16 Helpful votes
Hi,I need to buy an entry level switch with the following features:qos configurationsecurity features like port security, ACLs, NAC, IBNSlayer 3 featuresetmay or may not be modularat least 24 portsat least 6 POE portsPlease suggest the low cost model...
Scenario: I would like to be able to have a static block of ports and a dhcp block of ports on the same SG300 switch.ISP - Business Cable Cable Modem supplied by ISP has 1 Wan Port.I have:Static block of 8 usable IP addressesConnected directly to thi...
mattb by Level 1
  • 509 Views
  • 1 replies
Hi,I have an SG300-28P and I need to upgrade both the boot & firrmware versions.The problem is I can't find the boot file anywhere, the only file available on the Cisco downloads page is the firmware file ('.ros')These are my current versions:show ve...
ian-heath by Level 1
  • 3143 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
