Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2831 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4375 Views
  • 1 replies
  • 16 Helpful votes
I have two SGE2000 switches - one PoE, one not - in a stack configured for Layer 3 mode. On the stack, I have a VLAN (5) configured and tagged for all ports on both switches. I want to assign an IP address to the VLAN interface that I can use for rou...
hello, SG250x 48intervlan routing impossible...I have 3 vlan1 - with Static adress on vlan interface 192.168.1.254(gateway vlan1 computers)3 - with Static adress on vlan interface 192.168.3.254 (gateway vlan3 computers)100 - with Static adress on POR...
shellxy by Spotlight
  • 1724 Views
  • 4 replies
Hi,Expecting your valuable support to find root cause of intermittent /random network disconnection happening for intervlan (intervlan routing handled by firewall) & intra vlan communication.Please find the attachment.01. Network architecture.02. All...
Hi All I have a SG300 with the latest firmware. I have two modems attached to it via ethernet. DHCP is turned off on each modem so I'm using the SG300 to assign IP's via DHCP Server. Let me explain. Modem 1 : LTE Modem with static IP 10.0.0.2Modem 2 ...
