Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hi all, I am studying the best way to migrate two N7k to N9k . The physical topology is depiceted below:During the migration I will create vPC3 for L2 extention. The N7k swithes are in VPC peer-link and create a vPcs with a couple of FW in HA. The co...
irenof by Level 1
  • 192 Views
  • 6 replies
  • 1 Helpful votes
Hi team,I am observing below error in one of cisco Nexus9000 device. What is the resolution to mitigate this error.%AAA-1-AAA_SESSION_LIMIT_REJECT: aaa request rejected as maximum aaa sessions are in progressBelow is the version details..BIOS: versio...
SHAIKN by Level 1
  • 182 Views
  • 7 replies
I have a pair of 6880-Xs in a VSS pair with a strange configuration. I wanted to get some opinions before changing anything. The switches are connected by MM fiber as follows:Te1/5/1 <-> Te2/5/1Te1/5/2 <-> Te2/5/2The port states are:Te1/5/1 - connect...
Hi People,  I'm new here! I have a litte problem regarding the bandwitdh of 2 switches. It's between a switch MDS 9250i and a Switch Backbone IOS-XE ROMMON. Thery are linked with a 10Gbps fiber. The problem is that they never pass from 1Gbps.  interf...
Hi! I'm experiencing an issue where all PCs in VLANs 10 and 20 receive the correct IP addresses via DHCP. However, the client (PC4), connected to the same VLAN and switch as the DHCP server, is not getting the correct IP configuration. This problem o...
Hi Team, Whenever i am executing any command in a router or switch, i am receiving following error, if try for more than 2 to 3 times, the command stats executing. please advise what is the cause for this error and how to rectify this? CE ROUTER#sh...
WE HAVE PURCHASED 3 NUMBERS OF POE SWITCHES ( MODEL- C1000-24FP-4G-L)SERIAL NUMBERS AS MENTIONED BELOWFOC2822Y15J/ FOC2822Y181/ FOC2822Y18TFACING RMA ISSUES. WARRANTY NOT SHOWING AS PER DNA ESSENTIALS FOR 5 YRS FOR THESE ABOVE-MENTIONED POE SWITCHES....
