Switching
Get 20% off switches when you combine Cisco solutions
Labels
i experts, I'm getting this repeated notification daily since 3 days and now I received a complains that the IP phones keep getting restarted in the switch location offices.  logs from core switch : Sep 26 06:34:26.664: %SFF8472-5-THRESHOLD_VIOLATION...
I have a 3750 switch that currently will only display this error:%% Low on memory; try again laterThe only warning/error that is on our logging server previous to this is a traceback error. Thier is no history of this on this stack, and if it was so ...
 I have a question about HSRP and ACL configuration on Cisco 4506 and 4506E switches.Initially, without HSRP enabled, I configured the following ACL on the VLAN 55 interface:Extended IP access list vlan5510 permit ip any 192.168.104.32 0.0.0.1520 per...
poi05291 by Level 1
  • 150 Views
  • 3 replies
I know this has been discussed, but my situation may be more unique. We were having issues with a 24 port POE 3850 not being able to power all necessary cameras (13 I believe). It has two 710w power supplies which is more than enough for this applica...
frankTD4 by Level 1
  • 129 Views
  • 3 replies
MT-Test-01#copy flash1: tftpSource filename []? c2960x-universalk9-mz.150-2.EX5Address or name of remote host []? 192.1.2.200Destination filename [c2960x-universalk9-mz.150-2.EX5]?%Error reading flash:c2960x-universalk9-mz.150-2.EX5 (Is a directory) ...
