i have a cisco UCS C240m5 server that connect UCSM, i want to upgrade this firmware ,do i upgrade from ucsm or server cimc
The content you are looking for has been archived. View related content below.
My power supply is showing amber. Please help me find a solution.
Hello Freinds3 Disks in RAID 5, one of the Disk failed and start blinking Red , when we replace it with brand new disk , does it works automaticaly and automaticaly restore its raid 5 Parity thean the data on on it or it needs intervention from the s...
I have purchased a Cisco UCS C240 M5 server for our office, but due to the extreme noise we have stopped using it.I have already set the “Fan Policy” to Low Power, but it has not made any difference.What could be the reason for the fans running at su...
hi,i am trying to add 4 chassis and few rack servers to FI6454, the connectivity is fine. still un
we are experiencing similar issue on specif HW configuration of UCSC-C245-M8SX We have other UCSC-C245-M8SX with Different CPU and RAM without issue. Policies and templates are identical to all.
Cisco blades has a vKVM-Mapped vDVD1.22 boot option and boots to some sort of isolinux. How do you delete this ISO file/boot option in the bios and where is it saved on the server? All of the media has been wiped? I did a factory reset and scrub thro...
I have a question regarding the way WebBIOS utility erases RAID drive groups on UCS Server. In the documentation, I found this warning: Caution If you choose Clear Configuration or New Configuration, all existing data in the configuration is delet...
Hi All, I want to ask regarding UCSX IMM M7 Server after performing a firmware upgrade while the server is powered off, after the update nears completion and ESXi boots up then it goes to shut down . ESXi 8.0U3 is installed on the system. We observed...
Greetings,I have just noticed that certificate of CIMC has expired. I logged as admin but could not able to see some options as described in documentations. Product Name: UCS C240 M4SX any possibility to see which certificate has expired?Documentatio...
HiI have 2 server BE6H-M5-K9 with esxi 7.0I need to upgrade cucm from 12.5 to 15.One requirement of these upgrade is to upgrade esxi from 7.0 to 8The actual version of the CIMC BIOS firmware version is 4.1(2a)So I use the cisco UCS Hardware and Softw...
Hello,On C480M5 - CIMC is setup and is accessible via shared LOM. Now I've this major warning and I want to get rid of it. Please advise. Thanks F0717 - sys/rack-unit-1/mgmt/if-1 link missing Management Interface Link Down: LOM_P0 Check the netwo...
Hi,Configuring a new C240 and have noticed there is another option in the CIMC config page called "Shared LOM Ext". From reading guides this seems to suggest that I can share the CICM Management access with any of the LOM and also any of the Cisco VI...
I could use some guidance. I have not tried support yet from either Cisco or VMware but here is my struggle. I have an environment with probably 15 - 20 b200m5 blades. They are all set to legacy bootThey all boot local via local disks configured in a...
| Subject | Author | Posted |
| 12-03-2025 07:07 AM | ||
| 11-30-2025 06:22 PM | ||
| 09-23-2025 12:33 PM | ||
| 09-09-2025 06:54 AM | ||
| 09-05-2025 12:03 PM |
